Home > 998cc > Small intercooler
min79GT
Member #: 910
Hi all I'm looking into buying and intercooler for my 998t I have found one which measures 300mm x 155mm x 64 and the inlet/outlet 40mm would this be a good choice is to small/big ? Oh and I'll will be running it with a t2 with the mirage manifolds
thank you Lewis
1380
S2 RS Turbo Intercooler should fit the bill.
That sounds fine to me. Not massive but then we don't all have big ones.
Mine is quite long and thin, but fits snugly in the available slot.
*Rofl!*
Inlet and outlet are a bit small. the plendinidoodah is 50mm. not sure about the t2 outlet.
If buying an oem cooler, get the biggest you can fit in and get good airflow through it.
min79GT
Member #: 910
Thanks for the help guys
1380
