| Home > Help Needed / General Tech Chat > Opening cooper s rods out to a plus bearing diameter | |||||||
12th Oct, 2011 at 07:36:35pm
Having done some calculations to asses the feasability of doing a short stroke k-head engine I have run into a few issues, mainly by using a 70.2mm stroke with a 6 inch rod the piston will sit proud of the block. With the piston choise available the piston needs to sit around 70 thou down the bore to get the desired compression ratio of 9:1
12th Oct, 2011 at 07:53:51pm
an issue i found when i was looking to do similar (to build a stroked 1400 k-series) was that rods always have the rod bolts pretty close to the bearing diameter, so if you open the big end, you hit the bolts.. not sure if this is an issue on s rods, as its been a LONG time since i owned a set lol. turbo 16v k-series 11.9@118.9 :)
13th Oct, 2011 at 12:58:54am
^^^ What he said about the bolts On 26th Oct, 2004 TurboDave16v said:
13th Oct, 2011 at 06:38:08am
use the 70.2mm stroke crank, 6 inch rods and get some low pistons. Easy and it will work! I have an engine with a SA crank, std 5.75" rods and powermax pistons, and I had to skim the block 7 mm to get them flush. So really the pistons should not sit proud with a 6" rod anyway...
Edited by miniminor63 on 13th Oct, 2011. |
13th Oct, 2011 at 08:00:19am
On 13th Oct, 2011 miniminor63 said:
use the 70.2mm stroke crank, 6 inch rods and get some low pistons. Easy and it will work! I have an engine with a SA crank, std 5.75" rods and powermax pistons, and I had to skim the block 7 mm to get them flush. So really the pistons should not sit proud with a 6" rod anyway... also, running the pistons down the bore is a no no! get the cc's in the head instead! It would appear the only option to run the pistons flush with a 6 inch rod would be to use the +20 18cc forged omegas, as they have sufficient dish to get the compression down. I'd have just prefferd to use a 73.5mm bore to extract those extra few cc's! Then again not sure what omega have done to accrilite now, but they had a nice 18cc 73.5mm piston. John k is producing 6 inch rods now so actually, it would appear this could well be a goer:) On 7th Oct, 2010 5haneJ said:
13th Oct, 2011 at 08:02:55am
13th Oct, 2011 at 08:08:38am
On 13th Oct, 2011 apbellamy said:
Pistons can be dished out.... I doubt theres much scope for dishing on the med forged omega lightweight ones which I was planning to use on a plus 60 bore. A quick check on the avr technologies website has revealed they have the 73.5mm 18cc piston in stock. On 7th Oct, 2010 5haneJ said:
13th Oct, 2011 at 08:16:23am
I'd call them first mate. If something is worth doing, it's worth doing half of. |
13th Oct, 2011 at 11:12:50am
use the 70.2mm stroke crank, 6 inch rods and get some low pistons. Easy and it will work! I have an engine with a SA crank, std 5.75" rods and powermax pistons, and I had to skim the block 7 mm to get them flush. So really the pistons should not sit proud with a 6" rod anyway... also, running the pistons down the bore is a no no! get the cc's in the head instead! It would appear the only option to run the pistons flush with a 6 inch rod would be to use the +20 18cc forged omegas, as they have sufficient dish to get the compression down. I'd have just prefferd to use a 73.5mm bore to extract those extra few cc's! Then again not sure what omega have done to accrilite now, but they had a nice 18cc 73.5mm piston. John k is producing 6 inch rods now so actually, it would appear this could well be a goer:) Are these forged by now? On 13th Jul, 2012 Ben H said:
13th Oct, 2011 at 06:12:02pm
use the 70.2mm stroke crank, 6 inch rods and get some low pistons. Easy and it will work! I have an engine with a SA crank, std 5.75" rods and powermax pistons, and I had to skim the block 7 mm to get them flush. So really the pistons should not sit proud with a 6" rod anyway... also, running the pistons down the bore is a no no! get the cc's in the head instead! It would appear the only option to run the pistons flush with a 6 inch rod would be to use the +20 18cc forged omegas, as they have sufficient dish to get the compression down. I'd have just prefferd to use a 73.5mm bore to extract those extra few cc's! Then again not sure what omega have done to accrilite now, but they had a nice 18cc 73.5mm piston. John k is producing 6 inch rods now so actually, it would appear this could well be a goer:) Are these forged by now? They are as per all other SC rods I believe, which is open to interpretation
1425 Posts Member #: 690 Post Whore Norfolk |
13th Oct, 2011 at 07:19:17pm
I'll clarify, my rods are forged from blanks then cnc machined.
If Carling made Mini engines
13th Oct, 2011 at 08:41:13pm
On 13th Oct, 2011 johnK said:
I'll clarify, my rods are forged from blanks then cnc machined. Jk Thats what I thought. On 7th Oct, 2010 5haneJ said:
13th Oct, 2011 at 08:45:45pm
If so John, I'd quit writing billet rods. Billet rods are shite, forged ones are what we need :) On 13th Jul, 2012 Ben H said:
13th Oct, 2011 at 11:08:11pm
If so John, I'd quit writing billet rods. Billet rods are shite, forged ones are what we need :) Vegard, they are forged from a billet
13th Oct, 2011 at 11:15:50pm
PMSL!!
14th Oct, 2011 at 08:14:55am
If so John, I'd quit writing billet rods. Billet rods are shite, forged ones are what we need :) Vegard, they are forged from a billet ![]() Which comes from a forging?
14th Oct, 2011 at 10:55:45am
Billet is continiuous cast (similar to extrusion).
