Home > Help Needed / General Tech Chat > Plug leads for Segam & later type ford coil packs
Hi guys, I'm looking for some new plug leads, they got to be pretty long, anyone know of a car fitted with this type of coil pack with long leads?
Edited by Jimster on 19th Oct, 2011.
Ford ka there quite long, long enought to go round the engine back to the carb
Cheers Brett, I'll measure the wifes streetka leads.
Question for the technical ones out there, is there anypoint buying expensive plug leads for our application?
not really,... unles you get to st stage where you blow the spark out, or you have some EMF interferance issue...
that said I'm swaping to a set of spiral core ones cause I got them cheap off ebay.
i have that coil jim i bought my leads from halfords the hotwire ones
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
Got mine custom made (i.e. 4 leads to your specified lengths) from Canems http://www.canems.co.uk/catalog/index.php?...products_id=196
£30+VAT & P&P (£40.60 in total). Gavin @ MiniSpares recommended them.
Edited by Pottsy on 19th Oct, 2011.
http://www.ebay.co.uk/itm/CITROEN-XM-2-0i-...=item27bd289233
Pretty much all the 2 litre citroens between 1992 and 98 use these by the looks of it, and the Halfords part is HIL547. NGK part is RC-CR602
Longest is 860mm from end to end, shortest is 540mm and the other two are 700mm and 660mm respectively.
You can thank me when I'm next round yours for a bacon sandwich *happy*
Edited by Sprocket on 19th Oct, 2011.
cheers guys for the info
Jim I think I have a spare set of the Citroen leads Sprocket mentions if you want to try them.
