| Home > Technical Chat > My 1399cc dilema.... | |||||||
![]() 49 Posts Member #: 6752 Member Caerphilly, South Wales / Plymouth |
19th Oct, 2011 at 04:35:47pm
Hi All,
19th Oct, 2011 at 04:48:36pm
dont rely on whats stamped on the piston, measure the bore,
19th Oct, 2011 at 05:03:04pm
Just measured the bore, came out at 74mm.
19th Oct, 2011 at 05:08:22pm
dunno if the gaskets are as good, but somtimes you find the BK450's can overhan the bore on large over bores.
19th Oct, 2011 at 05:31:45pm
if the pistons are not for forced induction ..... (ie) the ring lands are narrow between them the slightest touch of detonation will quickley kill them.
Edited by BENROSS on 19th Oct, 2011.
19th Oct, 2011 at 06:15:46pm
Not negative at all benross, very helpful. I will just have to make sure everything is spot on so detonation never happens!
Edited by TrialsLife on 19th Oct, 2011. |
19th Oct, 2011 at 07:00:15pm
Measure the chambers in the head and confirm they are infact 30cc.
19th Oct, 2011 at 07:06:08pm
Cheers, that's the plan. I bought the head secondhand, and I know people who have had bad experience with Morspeed. Everything is going to be measured, can't afford to risk anything.
19th Oct, 2011 at 10:44:43pm
The Powermax 74mm pistons are +.020" pistons and marked as such. The 73.5mm powermax pistons are marked up as STD.
19th Oct, 2011 at 10:46:59pm
On 19th Oct, 2011 Joe C said:
dunno if the gaskets are as good, but somtimes you find the BK450's can overhan the bore on large over bores. The AF460 is a better gasket as its fire ring is a Gnats dick bigger. The BK450 does tend to overhang the bore a little when its compressed, more so depending on how well the bores have been offset. On 26th Oct, 2004 TurboDave16v said:
20th Oct, 2011 at 02:48:15am
On 19th Oct, 2011 minimole23 said:
Measure the chambers in the head and confirm they are infact 30cc. Many people have bought heads and found there not what they are stamped. I can confirm this. On 13th Jul, 2012 Ben H said:
