Home > Wanted > Lots of bits
jdisel
Member #: 9515
ireland
I'm on the look out for a good few bits i need for my mini project, i will probally end up buying most of these from minispares but i was thinking someone might have a few parts lying around going cheap. I live in ireland so would be handy if someone would have a good few parts to make it worth my while with postage costs.Ive no problem organising a courier to collect.
-rear hi-los
-megasquirt setup
-gearbox rebuild kit or a rebuilt gearbox to suit A+ engine
-minispares 4 pin diff
-a decent dump valve
-central locking kit
-full set of guages (oil temp, oil pressure, water temp, boost, AFR,volts and fuel pressure)
-A full set of new springs and standard size stainless valves for my 12g295 head.
-cam followers
-valve guide
Im sure theres alot more but ill start with this much Im also on a tight budget so cant afford to pay mega bucks for things but if someone has any few send me on a PM.
Thanks JP
Edited by jdisel on 6th Dec, 2011.
A job worth doing is a job worth over doing
Johnny
Member #: 6926
Accrington
ive got the minispares super cool 2 core rad (works great but looks a bit tatty in the cores from a bit of fan scrapage and where i had another fan attatched through)
i have some tim gauges too (oil pressure, water temp)
a boost and volt gauge (auto gauge)
all used, but work fine. PM me if your interested
Edited by Johnny on 20th Oct, 2011.
jdisel
Member #: 9515
ireland
PM'd
I thought of another few bits i need
-red and black steering wheel
-chrome door handles, window winder etc
-a centre spedo(that is if it can be easily fitted instead of the 3 clock setup i have, i have an old one already but its a bit rusty around the surround so a broken one would do once it looks good.)
-a new duplex timing kit
-clear indicator lenses,
-intercooler pipework (2")
-VR sensor bracket for megasquirt
-blanking plugs for dizzy and fuel pump
-a fancy looking rocker cover
-a set of speakers (4-6'') and maybe two small subs,(6'' or so)and an amp
-a black headlining
-a set of sportpack arches or maybe wide group 2's, havent decided yet,
-a handbrake gator/cover, not too sure whats around them, theres nothing on mine, just something to tidy it up.
-dump valve
-i also need all the bits to rebuild the engine, like pistons and bearings but doubt anyone would have any new ones around
-new brake lines
-+20 rebored A plus 998 block
-uprated 2 core rad
I know im being a bit ambitious with a few things, like an unwanted newly bored block, but i said id give it a shot *happy*
jdisel
Member #: 9515
ireland
bump
jdisel
Member #: 9515
ireland
I got my hands on a few things so updated the list and also added a thing or two,
Postage is costing me alot so id only be interested in buying a good few bits at once.
JP
jdisel
Member #: 9515
ireland
I also have a few metro turbo parts if anyones interested to exchange for a few bits i need.
I have
-a T3 turbo and manifold
-Metro turbo ecu
-metro turbo dizzy and ignition wiring(with used coil and leads)
All these parts seem to be in good used condition, drop me a pm if you have any questions.
jdisel
Member #: 9515
ireland
Bump,
Still looking for alot of bits.
wng691s clubby
Member #: 9252
Cleethorpes
i have a 998 A+ block you could get rebored pm if interested
what cam followers do you want? just standard ones
i also have a duplex timing gears and chain which seem to be good came off a recond engine
Edited by wng691s clubby on 17th Nov, 2011.
Done now needs redoing lol
jdisel
Member #: 9515
ireland
PM'd
