Home > Help Needed / General Tech Chat > mg metro block,with turbo
1275_dan
Member #: 441
ive gota 1275 mg metro engine, can i take the head off the turbo and whack it on the mg block and use that with the turbo???
pro's and cons please lads!
cheers
heads are virtually the same cc's (in theory!) so isnt going to make any CR difference.
MG metro engines are too high CR to just whack the turbo on.
Dont think there are any pro's!
Problem with turbo's is that they need to have a good build for them to be nice and reliable. you cant just bodge them together otherwise you get problems.
true iain
theres also the sodium exaust valves to consider which the turbo head sports
I wouldnt be worried about using the mg metro head on a turbo at all. If anything it may breathe slighty better (cant quite remember).
The OE valves are good quality and as a few people have found out turbo ones have been known to part the head and stem...
*smiley*
nutter driver
Member #: 47
Not very sunny swanage
mg metro heads have bigger valves...... not sodium filled tho like you say.... only pro i can think of is the mg cam is aparently very simmilar to a phase 2 cam? compression is only 0.2 higher that a turbo lump tho isnt it? (turbo 9.2, mg 9.4? could be wrong?)
Turbo 9.4:1
MG 10.0:1 *surprised*
I believe.......
thats the low CR mg as well tom i reckon. the unleaded one. the leaded one is a bit higher i think. not 100% though.
Turbo compression 9.4-1, nat asp MG 10.5-1. Only the leaded cylinder head had a larger inlet valve, the unleaded version was smaller apparantly.
Phil. *smiley*
ive got one in the garage so could check IICBA! *happy*
Pretty sure though the MG metro leaded and unleaded CR's were different. Really should look in my haynes but its downstairs!
antman
Member #: 358
Snetterton, Norfolk
It would make sense the unleaded ones being lower compression because 4 star has a higher octane rating so less chance of knocking with the higher compression.
