Home > General Chat > 22G1128 Gearbox - How can i dentify what it is exactly? How much is it worth?
davepugh1981
Member #: 397
Got a 22G1128 gearbox - its not a mk3 cooper s as the output flanges are different. How can i tell exatly what it is and how much is this worth?
Thanks
Dave
Dangerous
Member #: 417
may have a diff diff init
davepugh1981
Member #: 397
Could this be a close ratio gearbox? if so how can i tell?
Dangerous
Member #: 417
just looked in mini mag sept 03,case no 22g1128-part no 22g1338 all 4 syncro types with remote lever,cooper s is 22g333 31 26 21 18 on gears is c/r with 15 20 25 29 on layshaft
12G1128 is just a regular 68-73 998 remote gearbox. These were also found on Morris 1100/1300s.
Nothing special. Although it might be equipped with CR gears there no way you can tell by the number.
davepugh1981
Member #: 397
how many teeth should each ger have then? 15 20 25 29 is that right?
