Home > Help Needed / General Tech Chat > fuel pressure reg ??
100ev8
Member #: 9138
wolves
got the car running today but it keeps flooding out to the point it stops !
should you be able to blow through the fuel reg from the fuel feed to the carb outlet without restriction ?
if i turn off the pump it runs so sweet till it gets starved
rob
http://www.fishfight.net/
nope shouldt be able to blow through it,
whip the lid off see if the diaghram is split, if not check every thing moves ok, bung it back together and readust.
Yes you should be able to blow through the FPR inlet as long as the outlet is not blocked.
That's how fuel flows through it.
It would only become blocked if the outlet ( ie carb inlet ) was blocked by the needle valve or other blockage.
And also assuming the return port at the bottom is also sealed.
yep, scrub that,
on the pic below you shpu;d be able to blow from A to C, but none of the others.
Edited by Joe C on 23rd Oct, 2011.
100ev8
Member #: 9138
wolves
so it looks like the needle aint seating .....knew i should have stripped it before putting it on
Have you checked the fuel pressure?
Is the FPR turned to minimum?
Is there a restriction in the return pipe?
