| Home > General Chat > Just taken the Sprint\'s engine to bits | |||||||
26th Oct, 2011 at 09:23:19pm
Well as it was breathing heavily at idle (and has been for a long time, before I fitted the FI), it was time to see what was wrong.
26th Oct, 2011 at 10:02:04pm
pisser. I run a supercharger and I don't care the TB is on the wrong side.
26th Oct, 2011 at 10:16:34pm
Although one of the sceptics, I would say, from your description, it was probably already damaged before you fitted the EFI.
Edited by Rod S on 26th Oct, 2011. Schrödinger's cat - so which one am I ??? |
26th Oct, 2011 at 10:37:15pm
that on std998 pistons? are they the same as the 7ptt racer? Yes i moved to the darkside |
26th Oct, 2011 at 11:21:21pm
Same pistons that I've been using for years, first ones I've broken.
27th Oct, 2011 at 09:21:59am
Thanks for sharing that with us Wil.
27th Oct, 2011 at 09:51:05am
bad luck buddy, glad you found the faults at the end of the season and now just before an event. I'm going to do a full strip down on my engine in the next few weeks, although running great at the moment (apart from lose trigger wheel) not looking forward to what I'll find :( Team www.sheepspeed.com Racing
27th Oct, 2011 at 09:58:54am
On 27th Oct, 2011 Paul S said:
Thanks for sharing that with us Wil. Any chance of a photo of the cylinder head chambers as a point of reference? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
27th Oct, 2011 at 11:47:42am
Head photo
27th Oct, 2011 at 12:16:24pm
Not bad at all really will, and if the cr's lower then the boost ca go up.lol
27th Oct, 2011 at 01:14:51pm
That doesn't look any worse than mine to be honest.
In the 13's at last!.. Just |
27th Oct, 2011 at 03:15:12pm
On 27th Oct, 2011 wil_h said:
Head photo No, not too bad, although I would say that the outers are around stoich and the inners quite rich. What do you think the AFR spread is then ? What are those shiney areas near the inlet valves, clean metal? Edited by Paul S on 27th Oct, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Oct, 2011 at 06:02:23pm
so what pistons are going in now wil ?
27th Oct, 2011 at 06:16:58pm
Paul - Not sure what the shiney bits are, flash related bright spots, not obvious on the head. Not suer about AFR spread, but it runs rich im most areas at the moment, this is because of the amazing breathing system I developed to get rid of the smoke.
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
27th Oct, 2011 at 11:45:44pm
they are good pistons will there are ones a level up about 20 pounds more maybe, they are made for Forced induction.
27th Oct, 2011 at 11:59:21pm
Sorry to heart that mate, Glad you have a spare set all ready to fit. Best 1/4 mile 13.2 seconds @116 mph
28th Oct, 2011 at 07:19:16am
Have you got a link to the better pistons?
On 27th Oct, 2011 NickG said:
they are good pistons will there are ones a level up about 20 pounds more maybe, they are made for Forced induction. how many miles till this 998 pistons died? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
28th Oct, 2011 at 03:47:06pm
I didn't realise that the P20950 pistons were NLA. That's a bit of a blow for 998 Turbo builders. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
28th Oct, 2011 at 05:25:48pm
Indeed. Minispares stopped having them made owing to a quality issue. They have replaced them with a powermax piston I think, but it's only available in +40.
28th Oct, 2011 at 05:29:04pm
As an update, the car is all back together, no smoke, runs a treat. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
28th Oct, 2011 at 05:40:35pm
I see that Minisport.Aus are doing 1098 falt topped pistons from Mahle in +0.020/40/60.
28th Oct, 2011 at 09:47:49pm
Hey will they are the Graham russel pistons. He designed the hypatechs and make ones up from that again.
