| Home > Beginners Tech > Do i need to take the engine out to replace the clutch? | |||||||
![]() 106 Posts Member #: 9354 Advanced Member |
31st Oct, 2011 at 08:07:02pm
Well,
Apparently, I'm Wrong :[ |
31st Oct, 2011 at 08:21:29pm
It can be done in the car. Have you not got a workshop manual? This describes the process. You will need a flywheel puller.
31st Oct, 2011 at 08:23:35pm
It can be done in place with inner wings i believe, although a pain in the ass.
31st Oct, 2011 at 08:28:48pm
Took me 5 hours to pull the clutch, change the primary gear and oil seal on mine night before the RR day. Reckon I would have been quicker taking the engine out! If something is worth doing, it's worth doing half of. |
31st Oct, 2011 at 09:18:32pm
Clutch is easy with the engine in if the flywheel decides to come off nicely. If it is any bother is is difficult to get a good swing at it. Apart from that there is plenty of room. I have done it couple of times on my 1990 mini with the big servo master cylinder in the way. http://www.twin-turbo.co.uk
31st Oct, 2011 at 09:33:13pm
I've done it in a servo'd car, in the dark. It wasn't too bad. In the 13's at last!.. Just |
31st Oct, 2011 at 09:33:35pm
It's easy enough in-situ....as long as the bottom back 2 bellhousing bolts arent in place lol
31st Oct, 2011 at 09:48:15pm
On 31st Oct, 2011 stevieturbo said: These were one of the biggest ball aches of mine. And that the flywheel puller was so big that it didn't fit between the flywheel and inner wing.
as long as the bottom back 2 bellhousing bolts arent in place lol If something is worth doing, it's worth doing half of. |
31st Oct, 2011 at 10:03:29pm
2 hour job Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1st Nov, 2011 at 06:51:44am
wok wise ,slot the back hole and leave the bottom bolt out . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 140 Posts Member #: 1367 Advanced Member Cape Town, South Africa |
1st Nov, 2011 at 08:28:29am
You think the clutch is dead as it doesn't disengage any more? Surely there is another problem there? |
1st Nov, 2011 at 11:54:09am
With autocross minis we used to roll them on their sides for easier access for jobs like these ! |
1st Nov, 2011 at 01:20:08pm
Should take no more than a couple of hrs, you will need a flywheel puller and a nice long breaker bar will help Crystal Sound Audio said:
1st Nov, 2011 at 01:25:43pm
I must just be slow If something is worth doing, it's worth doing half of. |
2nd Nov, 2011 at 01:54:10pm
On 1st Nov, 2011 robert said:
wok wise ,slot the back hole and leave the bottom bolt out . I leave both of them out !! and weld nuts onto the engine mount itself, although I think mounts are available these days with nuts already affixed. 9.85 @ 145mph
