| Home > Help Needed / General Tech Chat > Engine block welding. | |||||||
![]() 174 Posts Member #: 9041 Advanced Member Essex |
1st Nov, 2011 at 06:43:37am
Hi guys on removal of my engine for re-build and upgrade I have found the most unsightly bit of welding on the back of the block. Anyone else had a block welded for any reason??. Was running fine before removal just not sure if it's worth putting back in. Any help would be apracated.
1st Nov, 2011 at 07:50:28am
Looks more like a fault with the sand casting to me On 26th Oct, 2004 TurboDave16v said:
1st Nov, 2011 at 07:51:24am
Looks to me like a bit of rough casting
Edited by minimole23 on 1st Nov, 2011. On 7th Oct, 2010 5haneJ said:
1st Nov, 2011 at 08:32:13am
As above. If you are bothered you could carefully grind it back with a carbide burr. Or just leave it as it is, it has been working as an engine for 20-odd years, so if it was going to cause any problem the chances are it would have done so by now.
1st Nov, 2011 at 08:42:52am
That's good news then as its on the back of the block it will stay as is as it can't be seen. Thanks again guys. |
1st Nov, 2011 at 09:05:33am
Yes that's just sand, should have been fettled out, poor inspectors me thinks Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
