Home > For Sale > Abandoning Race Car Project - West Sussex :(
andy_s48
Member #: 9671
Chichester, West Sussex, England
Hi all,
I've finally had to admit that I no longer have the time to complete this build, so am regretfully selling up. I've collected a lot of good parts over the years, most of them brand new, so hoping for them to go to a good home. They're not likely to see the track any time soon with me :( . I'm located near Chichester in West Sussex for collection, but will post smaller items for additional cost. Open to offers.
Will put up pics soon...
Andy
07590016888
Suspension
- Front subframe - Fully refurbished and powder coated metallic blue + new cones. Great condition apart from a few small scratches on the engine mounts £250
- Rear subframe - Same as above + new cones + radius arms £250
- Full front & rear polly bush kit. New. £25
- Front heavy duty on-car adjustable camber lower arms. New. £40
- Front heavy duty on-car adjustable Tie-bars. New. £25
- Rear adjustable camber brackets. New. £35
- x 4 GAZ adjustable dampers (full set) for lowered minis. New. £115 I also had these tested on a damper dyno and have damping graphs for anyone who's into that sort of thing *wink*
- x2 Front heavy-duty damper top mounts. New. £15
- x 4 Hi-Los kit (full set). New. £50
- 1 Pair of re-furbished Front hubs - Stripped, hammerited, lapped new ball joints, new roller bearings & steering arms. £80.
- Minisport steering rack. New. £40
Engine
- 12G940 cylinder head - Big valves, skimmed, ported & polished, double springs + rockers & push-rods. Good/used condition. £150
- Twin SU HIF4 1.5" carbs. Used condition, think the connecting tube has split. £150
- Maniflow LCB 1.75" exhaust manifold. New. £60
- 1275 (1300GT) A-series Short block, balanced crank + con rods, standard pistons, new oil filter, mechanical fuel pump, water pump, dizzy, alternator, ignition leads. Used condition. £175
- 1275 Gearbox, with differential, central oil pick up (new), magnetic sump plug. Re-built and good condition. £70
- A-series 1:1 ratio straight cut drop gears. Good condition. £200
- Ultra-light lightened steel duplex timing gears. New. £45
- Kent 286 camshaft. New. £70
- Matching oil pump. New. £10
- Cam followers (full set). New. £10
- AP Fast road clutch plate. New. £15
- Daewoo Matiz radiator + expansion tank. Light weight rad for front mount conversion. £45
Body Stuff/Composites
- Shell will be up for sale once I've found the V5
- Pair of doors with 4mm polly windows rivited in, homemade slider on driver's side. Winding mechanisms removed and inner panels cut out, will need finishing as still a little rough. Skins are in good condition, though a few rust spots & holes on N/S door. £35 each
- Minispeed carbon fibre boot floor. Good condition, a few scratches where a fuel tank has sat on top of it. £80
- 1-piece fibreglass front (roundnose). Used condition - cut but not painted. £65
- Fibreglass front brace bars. Good condition, some surface rust in places. £20
- Fibreglass boot lid. Good condition, painted. £35
- Pair of homemade 4mm polly rear quarter windows, fitted into original frames so can still open. £20 pair.
- Rear valance with drilled fog lamp holes, non-genuine. New. £10
- Rear O/S inner arch (complete), non-genuine. New. £35
Wheels/brakes
- 12" x 6" alloys with Falken tyres (<500 miles) from MWS. White with polished lip, good condition. £200
- Pair of drive shafts with driving flanges, standard brake discs, CV & pot joints + boots (x4 New). Used but pretty good condition £60 pair.
- Front standard brake callipers. Used, 1 good 1 pretty rusty looking. £20 pair.
- Rear hubs with brakes. OK condition. £50 pair.
- Non-assisted vertical type brake master cylinder. Used condition, think the piston has probably seized by now so will need blown out with compressed air. £60
That's all for now, I also have all of the usual mini guff kicking about, so ask if there's anything you want as I need rid of it all! Will get the photos up soon.
Not a good start your first post being for sale.... Should post up in the new members area and read the forum ruels... All members must show there location when selling (check control pannel) and showing pictures helps
And finally welcome
andy_s48
Member #: 9671
Apologies, I did read the for sale rules, however, missed the new member bit. Will get some pics up now.
Andy
andy_s48
Member #: 9671
Cambeeeeeree'!!
I'll have the 1300GT short engine if the block doesn't have the hole above the centra main. Could you deliver?
Pm me please.
rusty998
Member #: 6411
I will have the Gaz shocks if you can send them to Heathrow area ?
iTom
Member #: 9672
Nottingham
Dibs on rear camber brackets and 4 x hi-lo's!
Kean
Member #: 341
aka T2clubby
South Staffs
How has the boot floor been fixed to the car?
andy_s48
Member #: 9671
Front camber arms, rear camber brackets, top mounts and rear Hi Los have gone.
Front Hi Los are still for sale, brand new £30.
Rusty 998, sorry someone has already called dibs on the dampers.
Kean, the floor has only been trimmed, I didn't even get round to fixing it so it's not even drilled.
Is it possible to edited posts?
I'll post some more photos in a minute.
andy_s48
Member #: 9671
Some photos from today, all prices as above in first post-
Front & subframes, price includes everything shown
New Steering Rack
Hubs. I noticed a couple of the threads on the ball joints have been knackerd, so will include a brand new pair of ball joints in the sale as well:
Brake Master Cylinder
Brake callipers. One nice, one not.
Minispeed Carbon Boot Floor:
Single skin, Mk3+ Fibreglass Boot lid:
Fibreglass front:
Doors, white one will need some work on the bottom of frame, otherwise, both skins good:
Kean
Member #: 341
aka T2clubby
South Staffs
I'll take the boot floor mate, could you look into posting it?
I'll see if I can arrange collection by one of my minions.
andy_s48
Member #: 9671
Kean, yeah sure. Where do you want it posted to? Collection would be better if possible though as I wouldn't want it getting damaged in the post. Andy
andy_s48
Member #: 9671
Some more photos of the engine stuff for sale:
gregh55
Member #: 3636
herefordshire
hi, you got any pics of the rad?
andy_s48
Member #: 9671
No pics of the rad at the moment. I'll take some this weekend, get some dimensions and post them up for you.
Andy
Johnny
Member #: 6926
Accrington
i would have the steering rack PMd
andy_s48
Member #: 9671
GAZ dampers and front Hi Los sold.
Myamini
Member #: 8986
Bracknell, Berks
No mention of the alloy fuel tank, is it for sale?
How much?
andy_s48
Member #: 9671
Myamini,
Maybe, to be honest I haven't put it up for sale yet as I remember it had a leak from the filler cap when I water tested it (I made it myself). I was going to get a new seal for it, but never got around to it. If that's not a problem for you, then yes I'll sell it. It's a 14L ally, internal baffled, CNC laser cut & TIG welded tank with a Suzuki motor bike filler cap.
Let me know....
Andy
Myamini
Member #: 8986
Bracknell, Berks
How much are you looking for inc postage?
andy_s48
Member #: 9671
Gregh55,
The rad is about 570 x 380 x 65mm and weighs 2.5kg. Pics below:
Goacher65
Member #: 9652
Maidstone, Kent
PM'd regarding hubs, lower arms, and tie rods.
LouisT
Member #: 9563
Glossop (Derbyshire)
Is the steering rack a quickrack? If so how much and can you post?
