| Home > 998cc > Megajolt or Turbo Dizzy, | |||||||
275 Posts Member #: 4600 Senior Member Melton Mowbray, <BR>near Leicester |
6th Nov, 2011 at 10:52:41pm
I haven't bought either yet so I'm weighing up which will suit me best.
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
6th Nov, 2011 at 11:25:57pm
I have megajolt its brilliant worth every penny..Alan Main Build
6th Nov, 2011 at 11:29:27pm
But am I going to benefit hugely from it? I'm only running a timid 998cc! nothing serious! |
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
7th Nov, 2011 at 03:28:08am
i would get the good cam first. use the dizzy
7th Nov, 2011 at 05:47:40am
As Nick says, you can always add the MJ later whereas changing a cam is a bit more laborious. |
7th Nov, 2011 at 08:02:38am
As above but might be worth investing in the trigger wheel/bracket/sensor now as they will be a lot easier to fit with the engine out. Then save the expensive bit until later. Schrödinger's cat - so which one am I ??? |
7th Nov, 2011 at 08:17:46am
Why not do it right in the first place? A turbo dizzy will probably work. But it'll never be quite right. You'll benifit in all areas with megajolt. It'll start right, run right use less fuel etc
7th Nov, 2011 at 09:48:33am
It'll only take a month or two to reassble it all (as if, things will go wrong and it'll take longer)
7th Nov, 2011 at 10:30:26am
The MJ will make a massve differance. I wouldn't even entertain a dizzy now.
7th Nov, 2011 at 01:21:37pm
Reason I asked was after seeing this build:
7th Nov, 2011 at 04:05:42pm
Yep, flat out there is not much advantage having MJ. It is every other throttle opening that it becomes better. i.e 90%+ of the time driving. The MJ allows you to max out the advance when on light boost or no boost, improving MPG and drivability.
http://www.twin-turbo.co.uk
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
7th Nov, 2011 at 04:12:17pm
I have a mk1 metro turbo ignition setup if your intereseted, bought it but never used it because I havent got the engine back together - new cap and rotor srm included, silicon leads and brand new spark plugs will send piccies if your interested On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
