Home > For Sale > For sale-my complete engine
oli79
Member #: 8480
As title I have decided to offer my complete lump for sale as a full conversion, to include:
http://i165.photobucket.com/albums/u47/oli...otos/001-10.jpg
Engine-benross motor-1293 a + base on avonbar pistons, treated crank,centre main with cat bolt,arp rod bolts, std rods, phase 2 cam, duplex gears, benross head with stainless valves, sc box, sc drop gears with roller idler,2.95 fd,minispares 4 pin diff, ultralite flywheel, lightened backplate, grey plate,1.3 roller rockers.Steve should be able to confirm exact spec if needed
Minispares 2 core rad, new metro spec alternator and starter, carb complete, dump valve, fuel reg, ic and pipework, full megajolt kit, green air filter, new gt17 on mirage t2 manifold, lambda downpipe and full stainless fletcher exhaust system, clutch arm and slave cyl, full afr gauge kit with smiths rim, all oil pipework, all silicone hoses, bleed valve, boost gauge.
One minor issue has been on the tm run at santa pod recently, high boost saw some debris passed from the ic to the carb which locked the piston in the carb, i assume this is from inside the ic and from where is was welded when altered to fit the car, all cleaned and ok for the moment the ic is included but needs changing imo.
All items were new or refurbed when built, has done less that 3000 miles inc a few runs up the strip at Avon! Made 147 hp @16 psi at the fly at RGS on the tm rr day, has run up to 20 psi on the track. Fitted to my car for a full running inspection if needed-no test pilots.
In just parts alone I come to this owing me at least £4500+
Yours for £3500
PM me if interested
Thanks Oli
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
bennyy
Member #: 9037
Doncaster, yorkshire
Oki what's going on? Hope everything is ok.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
oli79
Member #: 8480
Hi Chief-yep everything is fine, oki is ok too!,not much going on at the mo but all I will say is B18c4
ta
oli
The dark side!
Remember " We will always be more powerfull that you can possibly imagine"
*happy*
I hope it is going to have a rotary muffler still Oli!
bennyy
Member #: 9037
Glad to hear your not leaving the mini scene, bring on the vtec!
oli79
Member #: 8480
Thanks all, only an idea for now and depends on getting a sale! And its going to mean some big changes to the car but it was either this or get rid, I was tempted by a 2.8i capri up until last week but you know how it is, and I have bills for this car easily double what I would get for it so decided to stick for now,looking to give the car more of a track focus but as much of the look kept, as for a hairdryer in the exhaust-well its part of the plan but maybe not immediately! Maybe just me but at the price and as a complete setup this is a gift to anyone wanting to build a turbo mini.
