Home > Help Needed / General Tech Chat > Car strength/safety
liam mini 35
Member #: 9125
Sheffield, South Yorkshire
Hi guys,
Just a quick question. I like the look of the seat subframes made by Topcat but i am rathr short and think i will be too far back in the car if i mounted somthing like that behind the cross member. So my question is how much strength/safety would i loose if i removed the cross member and welded in the seat subframes in its place? Also would this have any legal implementations? The car will also have a roll cage in it.
Thanks
Liam
The turbo build has finally started
Don't remove it.
You could make it lower to make mounting the seats easier, but it needs to be there.
just put a cushion behind you.
liam mini 35
Member #: 9125
Cheers guys. Il have to work somthing out then. Might get some wooden blocks on The end of my feet like the short stuff off indian jones.
what sort of seat are you mounting? I've mounted my MX5 seats on their original runners on a custom subframe behind the cross member but they cantilever over the top of the cross member for the shorter members of the family to drive
This is how I fitted my MX5 seats. Came forwards enough for the missus (5'4") and back enough for me (5' 10").
The rear was spacered up off the floor with inch ish spacers.
liam mini 35
Member #: 9125
Will that doesnt look like a bad idea. Im going to be using kirkey seats i think. Not seen anything else i like and they are a reasonable price.
mw3
Member #: 9590
Derby
ill try and get a picture up for you tonight and show you how i have mounted my kirkey seats, mine are up on the cross member like the previous picture
Matt W
On 14th Mar, 2012 mw3 said:
liam mini 35
Member #: 9125
That would be great if you could, thanks.
bosroamer
Member #: 1981
the Netherlands
Awesome seats, got those too.
Do yours weigh also more than earth itself?
I made brackets to bolt it to the original mounts and used some wood and ducktape (MacGyver alert) to raise the back of the rails.
On 8th Aug, 2010 Brett said:
Carl worked my bottom end, cannot fault the workmanship its spot on, a good old chinwag too :)
On 14th Nov, 2011 wil_h said:
Don't remove it.
That depends entirely on how good the cage is.
If it's a top spec cage, then I wouldnt be worried about the original crossbeam at all. If it's just a very basic cage, then safest to keep it.
theinjuneer
Member #: 9629
N E England
Gotta leave it in. Hugely important.
I used to talk to myself a lot until I realised I wasn't listening.
theinjuneer
Member #: 9629
N E England
Didn't pick up on the rollcage bit. Without the cage, don't do it. Be ok with the right bracing in the cage, though.
liam mini 35
Member #: 9125
Not sure what cage yet as im not putin it in yet jst gtin the welding done but it wii be an FIA/MSA spec cage.
Maybe if it's a full weld in mig cage. But a 6 point bolt in won't be much use in replacing it.
