Home > Beginners Tech > is this head ok for turbo???
steble
Member #: 9648
hi guys,
Is a 22cc head ok for turbo engines????
I assume it will be just double checking
I had it on my supercharged set up.
cheers
steve
Assuming that with all the other components it gives you a suitable CR, then it's fine. Generally though turbo engines run bigger chambers than 22cc
steble
Member #: 9648
its for my friend who thinks med were going to do him a 18cc one. he's doing a turbo engine build
If using 18cc pistons, 22cc in the head is great.
That's what we are running in the Miglia.
aim for a reasonable compresion ratio of around 8.5:1
