| Home > Help Needed / General Tech Chat > What loom | |||||||
![]() 183 Posts Member #: 9548 Advanced Member Manchester |
23rd Nov, 2011 at 11:18:59am
As the title suggests I have no idea what loom to use I have no wiring at all just bare shell so any help it's a carb set up running about 130bhp at 10psi is the target thx http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
275 Posts Member #: 4600 Senior Member Melton Mowbray, <BR>near Leicester |
23rd Nov, 2011 at 11:23:09am
What year? |
23rd Nov, 2011 at 11:37:13am
We could do with a little more info. If you are running a pre engaged starter, 2 or 3 clocks in front of the driver and carbed then a loom from the late 80's early 90's would be what you're after. Easy to modify for an inertia starter, and other bits and pieces if need be. On 26th Jan, 2012 Tom Fenton said:
23rd Nov, 2011 at 02:12:28pm
I WANa have a centre biconical and juststandrd starter motor with mega squirt http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
23rd Nov, 2011 at 02:33:17pm
I have a loom from a '78 central clock car. It's in a bit of a state, but should be OK with a little work. Looking for a tenner for it. Edited by apbellamy on 23rd Nov, 2011. On 11th Feb, 2015 robert said:
23rd Nov, 2011 at 02:47:48pm
standard starter motor could be either of the two, Andy's loom is a very good start though, you may need to faf about a little to fit a pre engaged on that loom as it should be for inertia.
23rd Nov, 2011 at 03:06:25pm
Yeah I will have it pm with details thx for help guys http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
23rd Nov, 2011 at 07:42:22pm
Just make your own, it's easy and a lot neater. Edited by MarkGTT on 23rd Nov, 2011. |
23rd Nov, 2011 at 11:40:06pm
I have no idea with electrics complete newb http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
24th Nov, 2011 at 07:55:40am
But your expecting to mod and fit a loom and run ms? Good luck. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
24th Nov, 2011 at 10:13:10am
Ya have to learn some how http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
24th Nov, 2011 at 10:18:39am
In that case why not study wiring diagrams and make your own? The standard loom is awful. Audi s4 b5 - 470bhp & 486ft lbs
24th Nov, 2011 at 10:22:27am
It's always handy to have something infrint of ya to visualise the diagrams ;p I am planning to make one but only after I work out what I do and don't need and conection plugs as I have no loom at all I would love to just buy one that does everything I want it to do but y not learn as ya go http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
24th Nov, 2011 at 11:22:07am
Has anybody got a full wiring diagram that incorporates megajolt? I mean alot of things would still use the same wires right? Things like the starter motor? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
24th Nov, 2011 at 11:23:54am
Have a look in my build thread. I've designed my loom from scratch On 11th Feb, 2015 robert said:
24th Nov, 2011 at 12:56:22pm
What Craig said would be amazing http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
24th Nov, 2011 at 01:18:16pm
apbellamy his thread is good has some wiring diagrams on page 17 and page 18 - however thats for an mpi car so I guess is kinda different.
24th Nov, 2011 at 01:26:19pm
Mine is not mpi. it has fuel injection connections on the loom, but you could easily adapt them for megajolt or megasquirt On 11th Feb, 2015 robert said:
28th Nov, 2011 at 06:13:28pm
Received the loom today thx any extra info to help find diagram of this loom would be much help thx http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
28th Nov, 2011 at 09:19:47pm
It came out of a 78 round nose. Diagrams are here:
29th Nov, 2011 at 07:37:13am
Thx for everything http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
