Home > Beginners Tech > metro turbo engine power
duncanmaclean204
Member #: 8838
INVERENSS
alright everyone its been a long time since i was on this site and this has prob been asked before but here goes.
I have got my hands on a metro turbo engine for my mini and i want to try and get as much power out of it as possible but without going in to deep with money.
my plan is to, whip the head off, get it ported and polished and put a high lift cam in it.
I have been reading alot of stuff about the engine and have been getting a lot of mixed reviews.
could you point me in the right direction. is it worth getting the chambers ground out so i can get more boost? how much boost could i put into the engine without it getting to risky? what kind of BHP would i get out of it? is it worth my while getting the flywheel lightened and balanced or would this just eat away at my top end speed?
any help would be great. thanks
IV BEEN IN THE WOODS TO LONG TO HAVE BEEN FUCKED BY A CROW
Right then.
Number 1, Please use the search feature on this site as everything you have asked has been answered many many times. *smiley*
Number 2, If it's a standard unrebuilt metro turbo engine I'll bet a fiver that its fucked and want rebuilding.
Oh and welcome back + good luck with your endeavours!
Edited by John on 28th Nov, 2011.
duncanmaclean204
Member #: 8838
INVERENSS
no worries will do my man. well iv actually whipped the head of it tonight and found that someone has been in before as its a bran new head gasket thats on it and the head and block are spotlace clean inside. so im wondering has someone done it up before and its never been back in a car. looking at its condition
Mr Joshua
Member #: 1954
Luton Bedfordshire
Is there a copy and paste post on here because I swear that post has been posted word for word several times *happy* *laughing*
Edited by Mr Joshua on 29th Nov, 2011.
Own the day
Firstly, as John pointed out, more reading needed.
A high lift cam is not the right idea. Turbo engine do not need high lift long duration cams, quite the opposite.
As a general rule, the standard engine is capable of making way more power than the standard gerabox an clutch can take.
But sadly the transmission is the costly bit.
Fit an IC, up the boost to 12psi happy days. Obviously you;ll need to make sure fuelling and ignition timing are all spot on. I'd be very conservative on the advance to start with, max 24 deg on boost.
scott the joiner
Member #: 9229
newcastle upon tyne
This all depends how much money you actually want to spend as every1 budget when they say not to much money is quite a bit different my first engine was totally std apart from opened chambers small intercooler set up green cotton air filter & 12psi the out come was 130bhp at the crank 105 at the wheels on peter burgess rr made a quick little motor on a budget
NickG
Member #: 7912
Australia oi oi oi!
How long did the engine last Scott on that boostand the gearbox?
Beno174k
Member #: 9548
Manchester
The engine will last a gd while before it need rebuild but it all depends on how u will look after it ! If u just jump in it Raff the arse off it and don't allow to cool down or warm up no engine will last as long as it could with a turbo engine it's all about cooling my engine build is costing me. 3500 with out turbo and that will be 130bhp at the wheels and I already had the metro turbo engine have u had a read of www.turbo-minis.com that's the best place to start as it explains a lot
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578
duncanmaclean204
Member #: 8838
INVERENSS
spot on for the infor there guys. reading threw other pages there is alot to take in with so many people doing so many different things.
I think wat il do is get head ported and polished. what is a safe size to take the cambers out to so that i can maybe up the boost to around 14/15psi
is there anyone got any pictures of a head after its been done?
so do you think its a good idea to leave standard turbo cam in it rather than putting a high lift one in it?
scott the joiner
Member #: 9229
newcastle upon tyne
Not to long to be honest then it done in the rings in 1 cylinder but it was an unknown engine so who knew how long it had new build now is ported head (chambers were already done) phase 2 cam total seal rings ported ex manifold upgraded intercooler picking my straight cut box up on the weekend set or roller rockers think that's about it setting boost to around 15-16psi wouldn't mind seeing it around the 160 mark which I think it should be
160 bhp in a mini scott is enough to grenade your arse out....... on the road
dig-mini
Member #: 9269
Rotherham
Here's a pic of my benross head this is the man for the job
Craig
This thread may be of some use.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=348364
