Home > 998cc > 1100 stock ish drop a turbo on it?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
so i have a 1100 3 year old motor and want more power.. but cheep
what could i get away with on the stock block,rods,pistons,crank,head
only things ive changed are the cam to a mild street and a DGV 32/36 i can get the cam specks it u guys like to help tell me if its use full on a turbo?
im thinking draw throw? would i have to change the DGV?
i don't really know carp about turbos and that i just want cheep thrills for now im not worried about it going bang.. i have more 998s and 1100s..
This is a common fit in small bore turbos
http://www.kentcams.com/product-details/17.../500-Mild-Road/
Engine will be fine as long as CR is 9:1 or lower.
Personally, i'd go blow through. Internals should be good for 120bhp, but you'll need a decent diff.
wez
Member #: 9271
Stoke on Trent
wasnt the 1100 engine around 8.3:1 cr standard? or 8.8:1?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
Sounds good the gear box needs to come out for new bearings any way I found some barring cage stuck to the sump plug! what should I expect from it?
What's a common turbo to use for my application?
can a webber do draw thro ?
Advantage
Member #: 1450
Near Paris - France
Turbo wise, I guess it wouldn't be of much help recommending the one of a Renault 5 GT turbo (wich is a Garrett T2) or anything from a 100hp turbo diesel car ...
Look out for turbos form similar capacity petrol engines or identical target output diesel cars, something in the 120 hp range maybe ?
Rusty by nature
Advantage
Member #: 1450
Near Paris - France
Ho and you can convert any HiF44 to turbo spec, there is a a guide here somewhere
Rusty by nature
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
Is it posable to use my 32/36 progressive down droughft webber? On a draw throw set up With out mods to the carb it's self if I can I only want to buy minamal parts
For blow through, without building a box to pressurise the carb from the turbo, then no, as the turbo pressure will prevent the fuel being drawn into the airstream, as a guide fuel pressure should be about 3.5/4psi higher than boost pressure. You'd be better off selling the weber and buying a HIF44 turbo carb, job done!
Unless you really want a suck through setup, which you could use the weber for, it wouldn't be amazingly economical, pretty limited and i 'think' you're going to need a specific type of turbo, again not ideal if you have to try and find one.
It would be far easier and probably cheaper to get a hif44 converted from n/a or the metro turbo hif44.
Edited by Carlzilla on 30th Nov, 2011.
Advantage
Member #: 1450
Near Paris - France
I would trade the Weber for a HiF44 and a better head / head work ...
Rusty by nature
