Home > General Chat > Final Drive 2.95 ?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i do 80% of my driving over 60kph (37.28mph) so will a 998 pull a 2.95 ?
how slow off the line will it be?
will it be crap in stop start traffic?
the car is not a turbo YET!! i plan on building one with advice from you guys and girls
Yes a 998 will pull a 2.9, some early 80's cars over here had it fitted as standard.
I drove a 998 with a 2.9:1 fitted for 2 years and to be honest didn't notice any difference in speed between that and the previous 3.1:1
It did struggle in top up moderate hills though.
To be honest my diff of choise is the 3.44:1 for a road car - especially if you mostly do 40mph.
Edited by minimole23 on 1st Dec, 2011.
ntm1275
Member #: 9395
When my 1275 engine blew up a few years ago, I stuck a 998 in for a short period until I got the 1275 rebuilt
The 998 had a 2.9 diff and it was the slowest Mini engine I have ever used
I was being overtaken on hills by articulated lorries, and I needed to change down to third, then second to maintain 40mph
If you are going to turbo it, that should give it the oomph it needs to pull such a tall diff
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
Hmm the hills on the freeway I drive evey day might prove tough then ATM Im doing a tad over 4 grand to do 100kph (60mph) and it drops 10kph on the up hill parts.. So from what you guys say I'll basically be going backwards! I guess the tall diff isn't a good option so I'll have to put up with the noise
I don't suppose ther is a nother way? 1275? 5speed costs to much
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
How did it go with hill starts ? Dose the fd affect the other gears much?
fit a 3.2 FD, this will be a good compromise ...... what wheel sizes have you got ?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
Yokhamas 175/50r13 a539? A593?
with 13's and a 2.95 you'll see about 4000 rpm at 80mph.
if your doing 60 at 4k currently it sounds like you have a 3.7 or 3.9
if its a standard is engine not making musch power say 30 odd HP go for 3.2 on those wheel & tyre sizes, possibley 3.1................ IMHO due to the hills
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
Hmm I'm some what confused can I have say short 1/2 gear and longer 3/4 gears? whould that give me decant acceleration but a good cursing rpm on flat ground I don't think I'd mind changing down for hills so long as the revs are below say 4k if that's evan posable in 3rd ?
I currently run the 2.9 on mu 998 turbo with 13" wheels. 80mph is exactly 4k (as above). It's fine in every situation, I've never really thought that I wanted it lower.
If you are worried just use a 3.1, slightly lower but still a grat diff for cruising.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
well ive decided to check out a mates 1275 i need to find out a bit about it first but im 80% sure ill get it and do a 1275 turbo im sure that that can pull a 2.95 diff..
the car will be intended to be a daily driver but i still want a fun car to take to the track and have a blast in..
i know ive got a lot of reading to do before jumping into it but im sure you guys can step me throw it with out things going drastically wrong!
NickG
Member #: 7912
Australia oi oi oi!
I have a 3.1 that's perfect with a good cam
Otherwise with out the power to pull the diff it is a slug..
Get Graham russels re 83t cam in there and perfect for turbo later *wink*
Edited by NickG on 2nd Dec, 2011.
what state of tune is the 998 in?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
I beleve it's a 998block with 1100 crank, rods and 1100+60 pistons stock 202 heAd but with new unleaded valves don't know the size? cam is 270 duration .3462 lift at the VALVE uk minispork ultra light steel flywheel presure plate what I'm now regretting a grey diagram! That will be coming out for a softer one and an ap disk the head has a 32/36 down drought webber on it and extractors I have a 123 disy too
The car drives well just ok it's got nothing under 2k cos of the carb I geuss but once the revs come up it's got more power and pulls nice to 6-65k
I don't understand the question.
You do 80% of your driving over 38mph. What you do not state is by how much over.
You also say that your engine is gutless beloww 2000rpm.
Fitting a 2.9 final drive at 38mph will put your engine right in the gutless area in fourth gear
Edited by Sprocket on 2nd Dec, 2011.
+.60 on a 1100 crank and hotish cam with a webber..... Along way from the fairly stock 998 i had in mind
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
My bad guys
Well the street I live in is 60 the next street is 80 and the next is 100 kph
from my driveway it's about 1k? To the freeway then I sit on that for about 30k then less than 500m to the office each day then most of the time jump in the work truck an go from there..
T3Tone
Member #: 252
Sunny suffolk
http://www.guess-works.com/Tech/ratio.htm
This is a handy gear ratio calculator i find useful.
-MINI CLUBMAN 1380 TURBO-
Advantage
Member #: 1450
Near Paris - France
I thought the 1100 with its longer stroke got plenty of torque low down, and I also believe it can stand more duration than a 998.
All in all, I find odd that it's got nothing under 2K.
Couldn't there be too low a compression ratio, or maybe the cam can be timed in with a tad more advance ?
Rusty by nature
