Home > Help Needed / General Tech Chat > Gearbox- rebuild or not?
jdisel
Member #: 9515
ireland
Im rebuilding my 998 engine in the new year and im wondering if a gearbox rebuild is necessary or not, its hopefully going to be a 998 turbo and aiming for around the 100bhp mark. The thing is ive never actually drove the mini so i havent a clue of the condition of the box, I havent rebuilt an engine before so its all new to me but would a rebuild sort out any problem that i could have with the gearbox,
Minispares have a bit of a discount these days so want to get it now while its cheap, that is if its definiately needed, Another thing, is this the correct rebuild kit.
http://www.minispares.com/Product.aspx?ty=...id=37117&title=
Its a 86 mayfair i have so its A plus.
Any help appreciated.
A job worth doing is a job worth over doing
Rebuild it!
Edit, also worth adding a 4 pin diff while your at it.
Edited by minimole23 on 2nd Dec, 2011.
jdisel
Member #: 9515
ireland
I supose a rebuild is the way to go,
Already have a minispares cross pin diff added to my long list.*happy*
Speaking of diffs, do i need to replace any bearing or anything when fitting a cross pin diff.
george91
Member #: 8932
It would be a shame to put a nice rebuilt engine on a used gearbox, especially if you don't know the condition, for peace of mind and your future plans its a no brainer imo.
You will need a pair of diff brgs, and also 3 off locktabs for the crownwheel bolts.
jdisel
Member #: 9515
ireland
Ya, i know what you mean but my thinking behind it was it would be a balls if i rebuilt the gearbox and it turns out theres something wrong with it, would a rebuild allow me to check for any abvious faults.
Im beginning to think a rebuild is a must, might as well i supose, *happy*
jdisel
Member #: 9515
ireland
So two of these (http://www.minispares.com/Product.aspx?ty=pb&pid=37231&title=)
, a cross pin diff and locktabs and the diff should be sorted,
Is that rebuild kit the one i want
i would its silly not too, even if its just a strip/ clean and inspect its well worth it and one of the simplest things to do imo
there is a dvd i would recommend for this - ultimate mini 1380 engine build dvd
alot of good info on there in general but the gearbox particularly as it shows you how to put it together
jdisel
Member #: 9515
ireland
a rebuild it is so. Ill check out that dvd.
wintersurferuk
Member #: 2208
Good call mate and its peace of mind as well, its horried thinking your gearbox is about to shit itself!
Personnally I would strip it and see what it needs before spending over £100 on a rebuild kit, but I have rebuilt boxes many times. If you know what youre looking at you will be able to assess whether all the bearings actually need replacing or not - same with baulk rings - you could save a fair few quid by just changing the ones that are necessary, you will ofcourse need all new gaskets though.
Most of us find you cannot go wrong if you follow a Haynes manual
Edited by paul wiginton on 4th Dec, 2011.
Get a metro haines manual. They are cheep and have a detailed gearbox rebuild guide in them. It's not difficult, just a little fiddly until you get used to it.
jdisel
Member #: 9515
ireland
I think ill just go for a full rebuild and put my mind at ease,i wouldnt mind ripping it up and getting my head round how each part works anyway,
Ill keep an eye out for that book too, might be worth a read.
Thanks again for the help
Another question, if a change my standard one to an x pin one, is changing the bearings a common thing to do or are the origional ones usually good.
in my opinion, if you are confident enough to assess the wear or damage to the original bearings, and are happy they are in good order, i'd use the original bearings where possible. The first and third motion shaft bearings being the important ones. As a matter of course I would replace the roller bearings in the laygear with genuine new items (not the ones Minisport sell) and where budget allows, a competition or Swiftune layshaft. Otherwise, again, it comes down to how confident you are at assessing the parts for wear or damage.
I try and only replace parts that really do need to be replaced, and try to find good used original ones instead of new. I might be the only skeptic, but I'm not sure of the quality of the parts available these days, what with all the bad and nasty things used in processes to manufacture these parts being banned, removed or replaced with something less suitable.
The first secont and third gear mainshaft needle rollers don't normally pose a wear problem and can be used again in most cases. Its important to ensure the end journal on the main shaft where the first motion shaft pilot bearing runs is in good order, as well as its sister journal on the inside of the first motion shaft itself. any wear or pitting there and its a new first motion shaft and main shaft, since this is one of the highest stressed areas of the transmission, which can allow the gears to push appart (marginally) under load in any gear except fourth.
The old style 'two part' diff bearings are, in my opinion, better than these new caged bearings, but again whether you can re use them comes down to how well you can assess them for wear or damage.
You will get all other wear parts, new with a Minispares cross pin diff, you only need to find good condition diff output shafts and crownwheel. If your original diff has lots of play in it (wiggle the pot joints when they are still on the box and pull in and out) chances are the output shafts will be worn, the bush in the crownwheel, and the bushs in the diff side covers will also be worn.
Don't let this put you off in any way, since the transverse A series gearbox is far from complex, but you do need to follow the haynes book very carefully, and if you still are unsure about anything, you know you just have to ask.
It also pays to have more than one gearbox you can use to build one good one *happy* 998 boxes are usually better, but 998 engines are now starting to fetch a premium, if you're just buying it for the gearbox *oh well*
jdisel
Member #: 9515
ireland
if i was to replace just the worn bearings, is there any fear that a couple thousand miles down the line the ones i didnt change would need replacing.
Ive never tinkered with engines before so dont know a thing about checking bearings or anything. Is it straight forward enough.
im a fan of 'if its done 100kmiles and looks as good as new there is probably another 100k left in it'
when i did mine i bought every bearing because i wanted a 100% new box
in reality the little bearings that sit under the gears on the 3rd motion shaft the old ones looked better than the new ones i had to put in, 2 out of 3 old ones went back in
ones i would recomend looking at and replacing
diff output bearings x2
1st motion bearings x2( on in box one in drops case) (38)
3rd motion double roller (19)
and the 2 on the layshaft (2 - 4)
found these articles there of the older box but roughly the same
http://www.7ent.com/pages/articles-tech-ti...ansmission.html
Edited by Brett on 10th Dec, 2011.
You'd know all about that, with 150nanas on top of a completely standard helical box.
jdisel
Member #: 9515
ireland
Cheers for the link
Would the rebuild kit listed below replace all the bearing you mentioned brett.
Just out of interest, hows your box holding up to that sort of power.
Im just getting a list of a few things i need for the rebuild so im planning on making an order with minispares tonight while the sale is on, just want to make sure the parts i have are suitable and if there actually the right ones, im not too sure if the clutch kit is right,
this is a copy of my shopping cart,
http://i1226.photobucket.com/albums/ee420/jdisel1/ii.jpg
I know theres loads of other bits to get, i just want to get the more expensive bits now to save me a bit of dosh in the long run.So if these any other obvious parts, shout,
Any help would be great *happy*
Oh ya, what cam followers would be the best, would the stand ones do the job or are the ones with the holes be better and what about a duplex timing set, do minispares do any performance ones, Another thing, these a valve spring missing on my 12g295 so would it be worth just getting a full set new, I also need a few tools for the rebuild, just wondering what sort of things i might need, I know i need a set of taps, callipers, dial guage,but other that that im a bit lost.*tongue*
Edited by jdisel on 10th Dec, 2011.
On 10th Dec, 2011 jdisel said:
Cheers for the link
Well I would not be happy putting more then 120 though even a well reconditioned helical box.
we'll see how I get on in the coming year then *hehe!*
Cheers for the link
Bang, grind followed by 'oh bollocks' I think!
Maybe.
One question though did that ^^ transmission have the KAD pinion support, swiftune layshaft, all end floats and the side clearance on each gear on the main shaft, set to bottom limit, and gear dependant boost control?
*happy*
I'll still likely break it though
Oh, and those gears ^^ look particulary well used
Edited by Sprocket on 11th Dec, 2011.
Maybe.
*happy*
It lived on a 998 for 60k before being rebuilt by someone who seriously knows their onions and fitted to a n/a 1380. Since the rebuild it covered about 40 miles around castle combe and 15 drag runs. The driver does not understand what mechanical sympathy is though which may not help!
there you go, 60k miles. The transmission is already pre stressed *happy*
A 998 couldn't stress a plastic gearset *tongue*
