Home > Help Needed / General Tech Chat > Tie bars
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Anyone know what safe dia I can turn the tie bar ends to give clearence for alloy calipers, ive already turned them down from square to round which is about 24mm..
Main Build
Upgrade to Turbo
I'd suggest getting a different type that have a standard end at the bottom arm and adjustment at the subframe end.
nala56
Member #: 9661
Do you know were to get the tie bars your talking about ?, or what they look like
Main Build
Upgrade to Turbo
The Kad bars work fine on mine mate.
nala56
Member #: 9661
Thanks mate will have a look, Its the price tag with kad that put you off..
Main Build
Upgrade to Turbo
delete
Edited by stevieturbo on 6th Dec, 2011.
First off, have you managed to set the length to give correct caster? You also have more droop as the rebound buffer is not fitted
I'm sure there are other people using such a design tie bar and four pots without issue. I have Minisport group A tiebars that use a similar design. I chose them beacuse the bar itself is not so bulky, and are on car adjustable. Tiebars these days are just too fat and bulky for my liking.
Edited by Sprocket on 6th Dec, 2011.
Check the clearance at ride height
nala56
Member #: 9661
Had these rods on for a while now with cooper s calipers, I set them to standed by putting them at side of the old tie rod, but would like to have the suspention fully adjustable in time, then will have it all set up right at the garage, had the jack under the ball joint to lift the mini under load but does not make a lot of difference, the tie rods are bulky to me, thats why ive turned them down, I think they look better for it, not made them any weaker at this stage..
Main Build
Upgrade to Turbo
I have those bars and they clear fine when the cars on its wheels
no issues with mine, i have the same tie bars and mini sport calipers ( look very much like yours)
nala56
Member #: 9661
OK guys, at this stage I will wait till the car is on its wheels before I do any more to the rods, thanks again its good to get this info because sometimes you carnt see the wood for the trees..
Main Build
Upgrade to Turbo
nala56
Member #: 9661
A quick update on the tie bars, Ive had the car on all 4s and your right there is no issue with the tie bars at all, theres loads of clearence, panicked about this because of rumers herd about the subject in the past, it only happens when the car is jacked up off its wheels..
Main Build
Upgrade to Turbo
That could be a problem if its a road car and has to pass an MOT.
Have you installed the rebound buffer under the top arms and have you yet to fit the dampers?
with dampers, the rebound buffers and the suspension geometry set correctly they still should not touch, even when jacked up
nala56
Member #: 9661
I have fitted the rebound buffers, but have not yet fitted the dampers, so I will fit them and report back.. Thanks for your input.. Alan
Main Build
Upgrade to Turbo
My callipers touch the tie bars on full droop, never been an MOT problem though
i have never seen them check for it, did not know it was a testable requirement?
My mistake.
They do check for fouling, lock to lock, but they do it with the car on its wheels, not at full droop.
