Home > Help Needed / General Tech Chat > Megajolt Cable Shielding
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys!
So ive been over to autosport labs reading their wiki and the only thing I cant get my head around is the shielded cable and earthing it.
so I chopped out the EDIS 4 diagram to save space:
Basically i cant get my head around the cable shield and earthing it.
If I bought shielded cable how would I go about earthing it?
Would i cut a load of the plastic off to get to the shield and then attach a wire to the pins on the edis? Do I just connect it to a wire and earth it?
Do I even need to earth it if I bought shielded cable in the first place?
Everything else seems easy enough just connect wires here and there.
With regards to the molex plug and rev limiters and tachometer:
Does the coil pack power supply conenct to the megajolt directly? Im guessing this is a yes in order to cut power to be able to limit the revs
The wire that goes from the coil to the rev counter atm - will I just connect that to the correct part of the megajolt molex plug and then it will work also?
Many thanks for your help so far *happy*
Craig
I've used the cable from the escort i got my stuff from. the sheilding simply loops into the earth cable - its a bit like a co-ax cable
Yep, you need to earth the shield, but only at one end.
earth it at the edis end to pin 7.
Craigie-B
Member #: 9468
Wootton Bassett
so i just need to earth pin 7?
edit:
how do I actaully earth it though? Thats the bit i dont understand how to connect it to an earth?
Edited by Craigie-B on 7th Dec, 2011.
Craigie-B
Member #: 9468
Wootton Bassett
have you guys got a photo ofhow you connected it, because all I can imagine in my head is having to chop the wire to get to the shield to connect it to a different wire ?
Actually, join the earth shielding to wire and then to earth. Just solder it or crimp it.
Craigie-B
Member #: 9468
Wootton Bassett
http://www.maplin.co.uk/twin-individually-screened-130
just found this, I can see from the bottom image that I was getting confused for no reason. Im guessing all of the shielded cables have it poking out the end like that and as such you can ground it easy enough :)
I can join the two together and then ground it in one place right?
that's it
Craigie-B
Member #: 9468
Wootton Bassett
excellent, one more thing do i connect the coilpack power cable directly to the megajolt ( I have a hard rev limiter) cheers!
no 2 on the coil pack plug to number 8 on the edis
Craigie-B
Member #: 9468
Wootton Bassett
yeah and then that to the megajolt molex plug?
Craigie-B
Member #: 9468
Wootton Bassett
edit: double post
Megajolt and edis both need 12v. the edis gets it on number 8
