Home > Help Needed / General Tech Chat > best places to get tapered malleable plugs?
davey_c
Member #: 9435
eire
where seems to be the best for getting them? i tried a search but nothing came up so thought i'd ask.
its for plugging bolt holes in the top of block and i see some have fitted the k100 head so thought you's might know.
cheers:)
dave, why not use threaded BSP plugs ?
Any good:
http://www.airlines-pneumatics.co.uk/webca...t.asp?SubCat=27
something like this?
http://www.kiowa.co.uk/products/pipe_fitti...lid_plug/KBSP14
http://www.rjpryce.com/Products/black-mall...-plugs/CR14808B
http://www.flowtech.co.uk/browse_product.a...%28Fig%20148%29
http://www.flowtech.co.uk/browse_product.a...id%20%28291S%29
http://www.airlines-pneumatics.co.uk/webca...tCode=S06015020
davey_c
Member #: 9435
eire
thats them thanks lads:)
tbh benross i don't know much about them, assuming they are standard water plumbing fittings but i was told that they have an odd thread size or something.. i might look into them though..
there made of cast all you need then is a 1/4" bsp tap 2nd tap .....and a drill for the large holes 11.2mm then tap
for the small holes on the block 1/8" bsp tap and a 8.4mm drill
it may be better to use hex plugs as i do and fit these flush ore a little under the deck height depending, if you are having the block decked ?
hex plugs ...... http://www.google.co.uk/imgres?q=bsp+hex+p...:20&tx=66&ty=90
davey_c
Member #: 9435
eire
thanks for that info mate, sounds like a winner:)
yes i was thinking of using those grub screws to plug the rest, their fierce handy.... i'm just going to het the block decked to bring the pistons flush
