Home > Help Needed / General Tech Chat > revs drop with clutch in???
Nick
Member #: 154
Midlands
got my engine running last night, i've changed to a pre verto flywheel now with a grey diaphragm.
just wondered if its normal for the revs to drop about 100 or so if that when you press the clutch in? you can hear the s/c drops rattling a little at idle but then they stop when you clutch in? am i worrying over nothing or should i be checking stuff out?
we've adjusted up the clutch as per haynes but seeing as this the first time i've messed with a pre-verto setup then maybe something could be wrong here?
havent driven it more than a foot yet, just tested 1st and reverse in the garage last night thats all.
Yes that can be normal. The spring on the grey diaphragm is stronger to give the increase clamping load. When you compress this, the reaction force comes from the thrust washers up against the crank. This force on them produces a force that counters the rotational force of the engine, hence it slows down.
Also correct what you say about the drops, they always chatter a bit when running, when you have dipped the clutch they stop rattling as they are not being driven, as the clutch is in. If anything, the noise stopping is a good sign as it means you know for definate that the clutch is releasing fully and is not dragging.
Kean
Member #: 341
aka T2clubby
South Staffs
Told you I was right dude.............. *happy*
one day you'll listen to me... *sigh* *happy*
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
hahaha, the proper phrase is "hate to say i told you so" *tongue*
Nick
Member #: 154
Midlands
cool thats another job thats gone ok then. :)
i'm off down to makro to get a new battery then so i can go for a gentle pootle round the block *wink*
It's when the revs drop by 1000 rpm or so you need to worry.
I seem to remember someone called egvard or somet like that showed a picture (only once) of some goosed thrusts?
Nick
Member #: 154
Midlands
took it out for a spin round the block earlier, all seems well. no strange noises or anything falling off anyway so we must have done a good job *happy*
how nice is the sound of a full s/c box!!!
egvard
Member #: 527
Hull
Oh yes. i wass unlucky enoght to experience dis myself. Hadto change the trustwashas. They was so badly done.
Light a man a fire, and he'll be warm all day. Set a man on fire, and he will be warm for the rest of his life.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Greys will eat your thrust washers... but then again without an uprated clutch you will not transmit engine power to the road!!
Glad you've got it on the road *happy*
alex
AlexF
Nick
Member #: 154
Midlands
ok cool, so a yearly strip and check is in order for definate then?
Congrats on getting it drivable! *happy*
A bit like thi. The thrusts on the left and right should look similar.
Edited by wil_h on 22nd Apr, 2005.
Mine were goosed as well Homepage is funnily enough down, so ni pictures.
Check crankshaft endfloat VERY carefully, and make sure that the diaphragm springs is completely flat. If you're running less then 10psi of boost I bet that an orange will suffice. I haven't tried, just comparing to N/A torque demands.
I feel that diaphragm colour codes are a bit of pub talk!
I mean, if you have a grey diaphragm, people surely will believe that you need it, thus, believing you've got a POWERFUL mota.
Did you try a properly setup orange one?
Edited by Vegard on 22nd Apr, 2005.
my clutch still slipped with a grey, I have done daves mod to the backplate now, if it still slips I'm going to have to try the double grey
In all honesty , I don't think that is the solution Jim. Dave and I ( Jon, Mark) do manage with the simple gray, and my grey one was not setup properly. I've now used Dave's mod as well, before this, the clutch did NOT slip, and the clamping pressure was not as high as it is now.
Maybe there are differences from diaphragm to diaphragm even if they are the same colour. British manufacturing tolerances remember :) Haha!
maybe, I have not tried my clutch since I have done the mod, I'll let you know how I get on
Mine still slips at peak torque... I should really be using a double grey - but that's just plain silly!!!
As I recall, the orange is rated at 100lb ft, the grey at 120 and the double grey at 135. The triple grey (NLA) must've been even more!!!
Edited by turbodave16v on 22nd Apr, 2005.
and to be fair thats very low compared to what you are actually running isnt it *smiley*
it's all bananans
apples and pears! *happy*
