Home > 998cc > standard 998
jamz
Member #: 2292
Tool
Herne Bay, kent
im in the process in building a nice track shell for my dad along side my project...
his rotten shell has a mint 998 engine with 20k on it...
he would like to make it go faster so far we have the other shell down to 560kgs... so that will help
but on a budget what can you sugest for the engine?
say on a 1k budget....
cant beat a good blowout.
If it were mine I would do.
12g295 head
t2 turbo on modified metro manifold
mg metro cam
4 pin diff
12psi
maybe a bit of megajolt thrown in too.
Others may be more qualfied to comment.
Was talking with a mate yesterday. We basically settled on that same spec for his car, but with mirage fanimolds.
hazpalmer
Member #: 9038
Carlisle, Cumbria
was that fani-molds andy?
booton
Member #: 9792
would u recommed changing the pistons for the added pressure or would standard dished pistons suitable with a good intercooler.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Read this if you haven't already.
http://www.turbo-mini.com/62147.html
Edited by Ben H on 7th Feb, 2012.
http://www.twin-turbo.co.uk
Spec sounds good james tbh..
booton
Member #: 9792
yeh read through it but i not say which pistons he used. i have two good complete blocks one with flat top and one with dished.
i though the dished would be better to lower the comp ratio
but the flat tops may be thicker not to burn holes in the top. but they could be the same thickness would not know.
Ben H
Member #: 184
The 20 hour Turbo used standard flat top pistons. You will ony get melting problems if your setup is poor or you over boost.
booton
Member #: 9792
ok. what would u recommend.
it think the dished pistons will be better to lower the comp ratio. might get away with a 940 head.
Ben H
Member #: 184
If you have dished I would use those. Do the CR calcs and see where you get to.
booton
Member #: 9792
will do hope fully can use a 940 head as i've finding it hard to find a 295
Advantage
Member #: 1450
Near Paris - France
You're after a 7cc dish (12G295 = 28.4, 12G940 = 21.4) as a 12G295 gives around 9 to 1 on flat top pistons in a 998.
You can calculate the dish from the stated CR from your model as a 998 head is supposedly 24.5 cc.
You can also measure it ...
Rusty by nature
wez
Member #: 9271
Stoke on Trent
i thought 998 standard dished pistons were 4 ring type so not really the best type to use???
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
booton
Member #: 9792
will pop one piston out tomz to show u. block in really good condition. standard bore 998.
seen lots of blocks this the best i've seen.
The 20773 will stand a decent amount of boost no problem. The issue is the circlip fitment. Best to use buttons.
wez
Member #: 9271
Stoke on Trent
ah, ok. I've got it in my head from somewhere on here about not using 4 ring pistons, might be something to do with 1275's maybe then. Or I'm just not remembering right full stop.
Also I was taking to an engine builder who said he prefers using circlip pistons and has had no issues revving up to 8/9 k with them. Is it to do with the boost that makes them pop off?
The circlips have always been a problem, boost or no boost. It's high revs that make them fail then funk your bores.
Would these been any good for a turbo 1098?
http://www.ebay.co.uk/itm/290669260045
