Home > Help Needed / General Tech Chat > Mirage Kit Remote Gearbox Install
Se7en
Member #: 446
Burntwood Staffordshire
Has anyone had experience fitting Mirage T2 kit to A remote gearbox equiped mini?If so can you help with these questions.
1) Will it fit
2) Will I need Pot joints or Hardy Spicers
3) Do pot joints fit remote box
Trying to keep magic wand gearchange by using 4 synchro
remote box to keep my MK1 in stealth mode
Thanks in advance for any advice/help.
It won't matter what gearbox you have, the Mirage kit will fit.
Phil. *smiley*
Se7en
Member #: 446
Cheers *smiley*
Was worried about exhaust clearance with the Hardy Spicers.
Ha, i see, thinking about it you'd be best off checking for sure. I know the downpipe runs close to the pot joint, the hardy spicer units may be worse as you suggest.
Best to give them a ring. *smiley*
Aren't Hardy Spicers of a smaller diameter than the pots? I'd hazard a guess and say it will be easier with HSs...
Mirage
Member #: 119
Im pretty sure you'll be ok. Sure we tried hardies in one car
I'll give you a refund if they dont fit.
