| Home > Technical Chat > Maestro Turbo in stead of metro? | |||||||
5 Posts Member #: 528 Junior Member |
22nd Apr, 2005 at 09:56:20am
i want to do a metro turbo engine conversion, but as they are now rare it is hard to frind one suitabel for a conversion so my question is would i be able to use a Maestro Turbo engine for a conversion? plz help |
22nd Apr, 2005 at 10:51:38am
maestro turbo engines are going to be even more difficult to find, then when you do find one they're an O series i think so in no way are they as easy a conversion as the metro one.
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
22nd Apr, 2005 at 01:08:28pm
theres about 6 turboe ngines/turbo kits on ebay last time i checked but i saw no meastros, and as bud says. there o-series, not an easy convert lol
22nd Apr, 2005 at 01:22:13pm
The good thing about the O-series is that is approx 600lbs. :) On 13th Jul, 2012 Ben H said:
22nd Apr, 2005 at 01:38:24pm
if your going to that extent, you may as well put in a vtec or xe lump, same amount of work Team www.sheepspeed.com Racing
24th Apr, 2005 at 09:29:21am
Thanks for the replies, but i ahve seen a company that do a mini egine frame for an RS turbo, what difficulties would there be for that conversion?
24th Apr, 2005 at 03:32:18pm
Ben,
AlexF |
24th Apr, 2005 at 05:51:46pm
I just seen a 94 meastro down the scrappy with a mpi block ? and a gearbox on the end of instead of under all mounted the wrong way round i.e. ports at the front sparkplugs at back loked well odd
24th Apr, 2005 at 06:08:47pm
What scrappy was that Dangerous?
AlexF |
24th Apr, 2005 at 06:33:58pm
challow near wantage,there is also a metro with vented discs and ap calipers down the far right by the wall
25th Apr, 2005 at 07:48:15pm
All the A+ in-line blocks (which is the same as a modern transverse layout) had a block that looked like the MPi one... they are different. On 17th Nov, 2014 Tom Fenton said:
26th Apr, 2005 at 12:03:08am
On 24/04/2005 17:51:46 Dangerous said:
I just seen a 94 meastro down the scrappy with a mpi block ? and a gearbox on the end of instead of under all mounted the wrong way round i.e. ports at the front sparkplugs at back loked well odd The Maestro's in later incarnations used a converntional type gearbox on the end of the engine, it was a VW gearbox I believe. (5 speed)
30th Apr, 2005 at 09:52:25am
O series engine......also found in Sherpa vans......what a piece of cr@p......although bolting the montego turbo assy onto a raggy old Sherpa would be quite amusing.....
3rd May, 2005 at 07:53:19pm
Yep i think you are right tom i have a friend who fitted a a series engine into a golf. He used a maestro block i think with all the turbo parts so that it was turbo. That was using a vw gear box. It was in performace vw magazine i think!! |
3rd May, 2005 at 09:00:37pm
Fitted an A-series - into a Golf?
![]() 1128 Posts Member #: 142 Post Whore Winchester |
3rd May, 2005 at 09:04:51pm
3rd May, 2005 at 09:50:13pm
I was just thinking - I'm sure I saw an a-series in a Nova shell once - it was a grass-tracker or something similar... On 17th Nov, 2014 Tom Fenton said:
3rd May, 2005 at 10:49:20pm
The best use of mini/metro parts I have seen recently was at an autograss meeting. Class Two cars are allowed up to 1300cc engines as long as they were fitted as standard to that car. Hence a Nova must use a Nova engine, Micra must use a Micra engine etc. The engines also have to breath through a resitrictor of a certain size (not sure what)
6th May, 2005 at 09:37:09pm
yeah its no bs i have the engine sittin in my garage!! it was nothing special but it was completely different! I know it used a a series block and crank from a maesto all tha turbo rods pistons,cam,head turbo carb etc!! was a mad car will try and find some more info. It was built by a lecturer at my old college!! |
