Home > General Chat > Mega jolt
coopdog
Member #: 9628
is there a mega jolt part to this forum?
if not i think it would be quite good if we had somewhere to post up your maps so other people can use it and help set yours up better,
what do you guys think?
MarkGTT
Member #: 1194
Shropshire.
It's good to share, but some of the maps have taken lots of time, trial and error / many expensive hours on the rollers to perfect.. I'm sure someone has a 'base' turbo map tho, similar to the dizzy equivalent for you to start with.
Edited by MarkGTT on 21st Dec, 2011.
John posted one up for the metro van. That did pretty well. Have a search for it.
there are alot of maps floating about i started off with the standard turbo dizzy timing put into a map and smoothed it off
Ben H
Member #: 184
Melton Mowbray, Pie Country
Most people do share their maps, be it MJ, MS or anything else. Just have a search.
The problem here is that there are no two engines the same and most map are fully optimised anyway.
http://www.twin-turbo.co.uk
carred
Member #: 9412
Austria
I am about to drop my engine into my Mini very soon and then I'll have to tune my MJ map as well. This might seem like a very stupid question to all of you, but how should I optimize my map so it suits my engine perfectly?
wng691s clubby
Member #: 9252
Cleethorpes
rolling road tuned
Done now needs redoing lol
The map that is on it is already pretty good. It was the one from the upside down skip.
The way to optimise a map is to run the advance on the raggedge of detonation.
However, this is a bit dangerous for the health of your engine (and pocket). also, from my experience the last couple of degrese advanve on a turbo motor make minimal differance to power.
dig-mini
Member #: 9269
Rotherham
This is from one of the users on here maybe something to help you here
http://www.jamesfawcett.co.uk/cms/index.ph...&gid=3&Itemid=3
Craig
basil
Member #: 9458
Hertfordshire
That link is dead, should be http://www.jamesfawcett.co.uk/cms/index.ph...ocman&Itemid=20
Ben H
Member #: 184
There is a bit more to it than that. When I say that most maps are not optimised I refer to the whole map. If you look at the map for the hillclimber the WOT and on boost bit is well developed after lots of trial and error, but the cruise area is pants and the tickover is not great either.
Best way to optinmise it is to log log log. Then make changes and log log log. Can you log on an MJ?
dig-mini
Member #: 9269
Rotherham
No it still works for me
Craig
carred
Member #: 9412
Austria
I decided to go the naturally aspirated route and got myself a 1380cc unit which will be fed by a Hif44. Restrictions here in Austria unfortunately make it almost impossible to run a turbocharged A-series engine. I suppose the existing map is optimized for a turbo engine?
Edited by carred on 24th Dec, 2011.
I think there are a few on the autos port labs site for NA engines
