Home > For Sale > Titanium bolt info.
All info has been removed as not to confuse the new page.
Go here to order.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=456918
Thanks simon.
Edited by madmk1 on 1st Jan, 2012.
Arent drive flanges 3/8 unf?
Mate, I was thinking of the bits on the back of the gearbox that hold the diff in lift & right.
Edited by madmk1 on 31st Dec, 2011.
I retract my previous statement.
Im interested in 5/16 UNC x 1" 10off
cool I was thinking its was going to be a none starter, the more we get the better the price will be for us, also it will be around 30 days to get them made so next payday looks good at the min.
Also i am thinking about Spring washers What you think.
I wouldnt worry about washers, the weight saving over stainless ones wont justify them, I generally dont use washers if I dont need to anyway
Edited by paul wiginton on 31st Dec, 2011.
This is why i ask for all the bolts to have flanged heads.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Will they have reduced spanner size over standard as well, like the a+ ones?
yes they should have a reduced head size.
I'm after the following bolts for my engine/rear subby.
Thread Length (Inch) Quanity
1/4 UNF 1 1/2 2
1/4 UNF 1/2 4
1/4 UNF 3/4 3
1/4 UNF 7/16 6
3/8 UNC 1 2
3/8 UNC 1 1/4 1
3/8 UNC 2 1/2 2
3/8 UNC 3 1/4 3
3/8 UNC 4 2
5/16 UNC 1 19
5/16 UNC 1 1/4 10
5/16 UNC 1 3/4 5
5/16 UNC 2 1/2 3
5/16 UNC 3/4 5
5/16 UNF 1 10
5/16 UNF 1 1/2 3
5/16 UNF 1 3/4 3
5/16 UNF 1 7/8 1
5/16 UNF 2 2
5/16 UNF 2 1/2 6
5/16 UNF 4 3/8 3
5/16 UNF 3/4 16
Comprehensive list Andy :)
jamestar
Member #: 9159
Devon
remind me to add to this list, when i find out what and how much i need
ok cool mate.
Most things to nail together an engine and the rear subframe.
Intrested in bolts for:
Alternator ( do you get nuts?)
Alternator bracket
Exhaust manifold
Thermostat housing
Hi gr4h4m,
Alternator -----------( do you get nuts?) ---------sorry no unless we get a 100 of them.
Alternator bracket ----------Titanium (UNF) 3/8” x 1 1/2”-----will do the inside one.
Exhaust manifold --------- Titanium (UNF) 5/16”x1” -----they is no studs but bolts will work
Thermostat housing -------- Titanium (UNC) 5/16”x1 ¾” -----if you are just using the housing i am sure they work
I hope this helps.
Does anyone know roughly what kind of weight saving you get wth these?
Lots and lots mate.
5/16unf Standard steel weight bolt = 14.4 grammes
Titanium bolt weight = 7.8 grammes
found this on ebay http://www.ebay.co.uk/itm/Mini-Parts-TITAN...=item3cb91a03e5
http://www.ebay.co.uk/itm/Mini-TITANIUM-5-...=item4ab220d694
Where does the cost with these actually lie ?
Would it be a silly suggestion, to say have them all made 2" long for any given thread size, and simply cut them to length ?
Or will they be making them with smooth shanks and then the threads etc ?
It would certainly make it easier to make up the 100pcs for any order. And perhaps more versatile as you find more places to use the bolts.
Hi mate,
It was the best quote i could find all in, with shipping and taxes etc.. so i am going with it.
As for standardising the bolts as you can see i have just asked for them to be 1" long so they have more uses than just in the eng. As for the bolts with a shank they will be an exact copy as the OE part with a 12 point head.
simon.
Interested in the folowing:
Wok bolts
Flywheel housing Bolts (both into box (UNC) and block(UNF)) These are longer than 1" btw
Slave cylinder
Edited by wil_h on 31st Dec, 2011.
cool i am going into the shed to get some sizes and pics.
supermotolee
Member #: 2153
kings langley
what about some wheel nuts?
miniminor63
Member #: 672
Oslo, Norway
Will they have hollow heads?
