Home > General Chat > Can Metro Turbo seatbelts be used in minis?
davepugh1981
Member #: 397
When i picked up my Turbo engine - the guy enclosed a nicepair of metro turbo seat belts.
Am thinking that these would look pretty cool in the mini - does anyone now if they are a straight swap?
Thans
Dave
yes I belive they are
i dont think so as the metty ones fit on a rail not a one bolt fixing if you get me.
turbo hogster
Member #: 178
stowmaket suffolk
they will fit but they are shorter over all and if you are small you wont be able to reach the peddals
Like Iain says, i thought the belt joined to a rail sort of mounting on the floor or inner sill, allowing them move ??
Whereas the Mini ones bolt to the inner sill.
Phil. *smiley*
mikemph
Member #: 449
Oxford
I think you can use the rear metro ones for the front of a mini, but not hundred% sure
Metro rears go straight in - but as hoggy says - you can't be: a) a fatty or b) someone who drives like a girl - ie 1cm away from the steering wheel.
I had a few brackets laser-cut from 4mm steel to take the front belts... Don't know where I put them mind!
