| Home > Wanted > Someone with a lathe to knock something out for me. | |||||||
5th Jan, 2012 at 09:06:11pm
Slightly off topic, but a lot of you seem to make all manner of things. I am going to convert a discovery gearbox to fit my defender, due to decent defender gearboxes costing tonnes. I have bagged a low milage discovery for a bargain price, therefore need to convert it. This is done by making an adaptor to extend the selector shaft to accept the defender shifter remote.
Edited by minimole23 on 5th Jan, 2012. On 7th Oct, 2010 5haneJ said:
5th Jan, 2012 at 11:01:19pm
I could knock something like that up. What material were you thinking of? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
6th Jan, 2012 at 08:20:27am
It would probably need to start out as a piece of 35 or 40mm mild steel bar, so nothing to exiting! On 7th Oct, 2010 5haneJ said:
7th Jan, 2012 at 09:37:05pm
Should be doable. How desprate are you for it? I need to sort my tailstock out first. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Jan, 2012 at 10:13:26pm
I think MRA have copyright on that, so be careful!!! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
7th Jan, 2012 at 10:20:27pm
Hahaha! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 825 Posts Member #: 2208 Post Whore Essex |
8th Jan, 2012 at 05:14:59am
BUTT PLUG! |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
8th Jan, 2012 at 09:41:07am
When i saw your diagram first thing that came to mind was a toilet roll holder - this just me or anyone else? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
8th Jan, 2012 at 05:17:53pm
On 7th Jan, 2012 matty said:
Should be doable. How desprate are you for it? I need to sort my tailstock out first. I'll let you know matty, I'm gonna see if my machinist will let me occupy a lathe for a while as it would be good to be able to offer it up to the box to get the size bang on. I decided a camshaft will make a nice donar for a lump of metal, just turn a little off one of the journals and de-lobe it a bit, it'll even sit nicely in the lathe using the camshaft drive. On 7th Oct, 2010 5haneJ said:
8th Jan, 2012 at 05:25:23pm
You are aware that cam shafts are hardened and a bugger to machine? Isambard Kingdom Brunel said:
8th Jan, 2012 at 05:40:38pm
On 8th Jan, 2012 Rob H said:
You are aware that cam shafts are hardened and a bugger to machine? The one I attacked with a hacksaw the other day didn't seem too bad, its not like I need a whole camshaft delobing for 16v conversion, but point taken. a bit of bar may be easier to machine. On 7th Oct, 2010 5haneJ said:
8th Jan, 2012 at 05:48:20pm
Just let me know, if you don't have any luck. I found some mild steel today that will do the job nicely https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
