Home > Wanted > 3 piece Turbo calipers wanted
I'm after a set of those four pots for vented discs that has the spacer in the midddle. BIR was fitted with one of those, but I need another. This way I could bin the horrible vented discs, but still have some pad surface area.
Anyone?
jukka
Member #: 60
Forgotten more than most ever know
You want to use solid discs with 4-pots ?
I believe early metros had this setup ?
Yup!
I beileve so too...
mikemph
Member #: 449
Oxford
how come you want to bin the vented disc?
Have you lilfted one?? Unneccesary weight.
mikemph
Member #: 449
Oxford
lol ok i see.
Must admit i have used non vented before and for road use they are great stay warmer so you get a better bite where as the vented go off cold and little less consistant but will take more abuse on a track or where braking is more offen.
sandfly
Member #: 444
mini speed sell them new for about £70 each i think
Still after some 2nd hand ones :)
Dangerous
Member #: 417
Bit late
Just found a pair on my 1983 mg metro need a rebuild.
I will just get some normal ones unless I change to vw/ford struts
Still after a set og these!!!!!!!
Edited by Vegard on 13th Nov, 2006.
Guess what i've just found in the garage ? *happy*
I used to have them fitted to my car and they were fine {changed them for Minispares alloy 4pots} since then they've just been sat in the garage, so as far as i know they should still be ok....
They're quite heavy as you know, so £30 inc UK postage ??
Phil. *smiley*
Phil. You're a star.
I'll definately have them if they're the three piece variety.
They're 2 piece, but they're for solid discs, not vented. *smiley*
Of course. I guess they're missing the centre piece then :)
