| Home > Help Needed / General Tech Chat > primary gear to clutch assembly order | |||||||
![]() 168 Posts Member #: 9709 Advanced Member Cirencester, glos |
9th Jan, 2012 at 08:07:28pm
hi all,
10th Jan, 2012 at 12:20:12am
It goes:
Edited by matty on 10th Jan, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Jan, 2012 at 12:23:10am
Thank you very much I missed out one of the thrust washers I glad I asked :)
10th Jan, 2012 at 12:29:47am
Remember to check the clearance between the end of the primary gear and second thrust washer. Edited by matty on 10th Jan, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Jan, 2012 at 03:09:11am
Sorry to be a pain, how do I know which thrust I need? Is it determined by the end float of primary gear
Edited by Rickus on 10th Jan, 2012. |
10th Jan, 2012 at 08:58:24pm
what does the thrust washer look like that goes against the primary gear? |
10th Jan, 2012 at 11:17:42pm
This is the one that goes before the primary gear. You need to fit one, then using a feeler gauge measure the gap between the end of the primary gear and the second thrust washer. If the endfloat is wrong order the right width thrust washer to correct the gap.
11th Jan, 2012 at 12:31:10am
I thought so the second thrust is that the c clip back plate or the gear housing itself
11th Jan, 2012 at 08:21:10am
11th Jan, 2012 at 08:59:53am
Yeah the C clip 'back plate'. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Jan, 2012 at 05:32:27pm
Ok that's brill, thank you again Matty. |
