| Home > General Chat > Hardy spicer vs pot joint | |||||||
11th Jan, 2012 at 08:28:29pm
What do you guys prefer? Pot joint should be a smoother rotation but what does that gain? I seriously doubt it! |
11th Jan, 2012 at 08:36:35pm
which is the lighter setup dave,
11th Jan, 2012 at 08:38:00pm
I havent yet Carl I seriously doubt it! |
11th Jan, 2012 at 09:39:23pm
On 11th Jan, 2012 paul wiginton said:
I havent yet Carl fucking slacker, |
11th Jan, 2012 at 09:42:16pm
I like pot joints as there are less bolts on them!
11th Jan, 2012 at 09:48:52pm
2/3 of the way down this page Paul...
In the 13's at last!.. Just |
11th Jan, 2012 at 09:54:06pm
Pot joints all the way, i hate putting the nuts on the bolts of spicers!! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
12th Jan, 2012 at 12:44:31am
Pot joints all the way.. Cheap, strong, quick to fix, easily sourced.....
12th Jan, 2012 at 08:05:00am
pot joints for me too On 11th Feb, 2015 robert said:
12th Jan, 2012 at 08:25:23am
I've always used pots but can see the appeal of spicers. No either draining the oil or pulling boots off when removing the engine. If something is worth doing, it's worth doing half of. |
12th Jan, 2012 at 09:58:50am
Spicers, for the reasons John mentioned. |
12th Jan, 2012 at 10:06:40am
On 12th Jan, 2012 John said:
I've always used pots but can see the appeal of spicers. No either draining the oil or pulling boots off when removing the engine. Nice argument but with us, 9 times out of 10 when an engine comes out it needs to be stripped down anyway because we've broken something. Removing an engine without spiltting pot joints is easy enough with a bit of wiggling. On 7th Oct, 2010 5haneJ said:
12th Jan, 2012 at 10:11:34am
Yep mole thats how I have always done it. But the alternative to splitting the boot off the joint is popping the pot out of the box. If something is worth doing, it's worth doing half of. |
12th Jan, 2012 at 10:18:33am
Yep mole thats how I have always done it. But the alternative to splitting the boot off the joint is popping the pot out of the box. Sorry thats what I ment, don't want to be getting crap inside the joint so I use that method. On 7th Oct, 2010 5haneJ said:
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
12th Jan, 2012 at 01:07:13pm
Carl,,, how`s about some titanium pots next then ?
www.miniman.com.au
12th Jan, 2012 at 01:24:37pm
spicers are cheaper to replace the jointy bits on... On 28th Aug, 2011 Kean said:
12th Jan, 2012 at 01:29:40pm
Depends how you get the engine out. I don't use a hoist so the wiggle option is out of the question. Hence, I usually end up splitting the uprights from the top arms and separating the pot joints from the box.
Edited by Paul S on 12th Jan, 2012. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
12th Jan, 2012 at 05:04:35pm
i suppose you think your clever and getting that one in first ha ha, wrong,i already started on that about 2 years ago, but had no wqay to put thew vball grooves in , untill now but its on the backburner,lolo
On 12th Jan, 2012 MadMatt said:
Carl,,, how`s about some titanium pots next then ? |
12th Jan, 2012 at 07:18:47pm
If i recall these were serving a great purpose as paper weights in your study carl what what!
On 12th Jan, 2012 fastcarl said:
i suppose you think your clever and getting that one in first ha ha, wrong,i already started on that about 2 years ago, but had no wqay to put thew vball grooves in , untill now but its on the backburner,lolo On 12th Jan, 2012 MadMatt said: Carl,,, how`s about some titanium pots next then ? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
12th Jan, 2012 at 07:22:25pm
ive heard of people breaking the pot joints? how strong are they? would you use pots on a 200+ bhp engine? |
12th Jan, 2012 at 08:14:10pm
I think the majority of people with 200bhp + are running pot joints.
12th Jan, 2012 at 08:16:31pm
I belive both the minis that have made over 300bhp use pot joints, there are also thoes bad ass uprated shafts you can get which are like thoes found on the back of a bmw or vws not sure what there called though but there like a mix of pot and hardy Drives
12th Jan, 2012 at 08:37:36pm
i think i will stick with my pots then, thank you for the info |
12th Jan, 2012 at 09:01:40pm
Hardy Spicer assemblies seem to be significantly lighter than pot joints I seriously doubt it! |
12th Jan, 2012 at 09:06:09pm
which two mins are you talking about paul
On 12th Jan, 2012 Paul R said:
I belive both the minis that have made over 300bhp use pot joints, there are also thoes bad ass uprated shafts you can get which are like thoes found on the back of a bmw or vws not sure what there called though but there like a mix of pot and hardy |
