Home > General Chat > Pistons!
thefro1991
Member #: 9385
Hi every1,
Just wondered what pistons most people are using for high boost appilcations, as i'm not sure which ones to get
Cheers, francis
Forged omegas, cast omegas, accrilites are the main ones.
What do you want to do with the engine, target power, compression ratio the list is endless some more information is required.
I'm using Accralites.
eden7842
Member #: 8852
leicestershire
Accralites
welshdan
Member #: 1111
s wales
has the availability of accralites changed? i am soon to be in the market for some uprated 18cc dish pistons. i havent been able to find anywhere that stocks these pistons, omegas seem to be more readily available? cheers, dan
Omega bought out accrolite
welshdan
Member #: 1111
s wales
so all of the pistons will be branded omega now? cheers
if your budget can stand it, used forged omegas as accralites are NLA only if someone comissions say a dozen sets.
cast omegas are tried and tested in forced induction and take the punishment metered out to them if the fueling and timing advance is set correctley to avoid fueling lean out or detonation........ there isnt a piston on this planet can stand the above.
hope this helps *smiley*
Edited by BENROSS on 12th Jan, 2012.
Forged omegas here.
mw3
Member #: 9590
Derby
Forged omegas
Matt W
On 14th Mar, 2012 mw3 said:
scott the joiner
Member #: 9229
newcastle upon tyne
std turbos with total seal rings
Good point, std turbo pistons are up to whatever people have thrown at them providing fueling and ignition are spot on, but then this sould be the case regardless of piston choise.
if you can find good condition ones
Van's std turbo pistons took up to 25psi without any whoopsies!
Mr Joshua
Member #: 1954
Luton Bedfordshire
Well that's good to hear as I have built my engine with +20 20831 (std) pistons *smiley*
Own the day
thefro1991
Member #: 9385
cheers! turbo pistons it is :)
