| Home > Help Needed / General Tech Chat > Water cooled Turbo, can i plumb it like this ? | |||||||
25th Apr, 2005 at 06:38:58pm
I've done a bit of a search and found a couple of topics that helped, but what i need to know is could i plumb my water cooled Turbo in line after the heater where the pipe comes out the bulkhead, then into the bottom hose ? would this be ok ? |
26th Apr, 2005 at 12:55:27am
i would say phil
![]() 270 Posts Member #: 69 Senior Member Coventry |
26th Apr, 2005 at 10:15:48am
I would recomend not water cooling it, in a mini especially a turbo you struggle with high water temperatures anyway, dumping turbo heat into the water would only make this much much worse, unless your running a front mounted rad and some serious fans.
26th Apr, 2005 at 10:18:32am
An oil cooler used to cool water is a waste of time. They do NOT make good water radiators, mainly due to the fact they are designed to deal with a completely different viscosity of fluid passing through them.
26th Apr, 2005 at 10:28:30am
and a water cooled turbo is a good idea |
26th Apr, 2005 at 10:46:39am
Phil, I'm taking the water from the bottom hose, through the turbo, then I have a y connector, taking water from the turbo, and the heater output on head, through oil cooler as second rad, and then into top house, (via metro thermostat housing)
26th Apr, 2005 at 11:35:21pm
Cheers guys ! Nearly done now, should be back on the road tomorrow so i can test out the new Turbo. |
27th Apr, 2005 at 09:23:11pm
what turbo you gone for phil? Team www.sheepspeed.com Racing
28th Apr, 2005 at 02:18:35pm
yeah, what turbo have you gone for Phil? On 17th Nov, 2014 Tom Fenton said:
28th Apr, 2005 at 06:55:10pm
Late spec Renault 5 jobbie. Was gonna stick with the T3 so i sold my Mirage set-up to Iain. I knew my faithful old T3 was about ready for a rebuild so i was gonna get it rebuilt by Turbotechnics,but this wasn't cheap ....
28th Apr, 2005 at 07:39:09pm
you will never go back to a t3
29th Apr, 2005 at 12:08:33am
I wouldnt return into your bottom hose as it will feed hot water back into the engine.
29th Apr, 2005 at 12:09:44am
+ i run with a 2 core side mounted rad, plumbed in turbo and have NO heating problems what so ever. I found it made no difference to the temp at all.
29th Apr, 2005 at 02:08:48pm
Yeah that's what i was thinking about putting hot water back into the bottom hose.
29th Apr, 2005 at 05:49:01pm
bodge?
29th Apr, 2005 at 07:28:58pm
looks factory to me!
30th Apr, 2005 at 12:32:35pm
anyhow, with any luck it will heat your car up phil, if your unlucky it could be as hot as your sister
