Home > Wanted > Wet/Hydro Top arms
Probably a long shot, but anybody got a set going spare?
best_stig
Member #: 6449
Brisbane, Australia
Im pretty sure I do, postage might be a bit though. Yours for the cost of postage if i have them and you want them.
In boost we trust
That would be good if you do have them. Let me know the cost of shipping plus a couple of tinnys *smiley*
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
Try Tim at Minimail , Tel: 07000 850 1275 or
Tel: +44 (0) 1989 720111
he had several pairs last time i visited
Thanks, I'll see what Joe comes up with then have them as back up
Dont forget hydro arms are about 200g each heavier than dry but they can be lightened cosiderably
Any tips on lightening them Paul? Is it just a case of tickling them with the grinder to remove excess material?
Dont tickle them, fucking carve them. see if WilH has any pictures of his which were mine
I can get pickies if you want. Paul dod a lovely job on the ones I have.
That would be good if you wouldn't mind Wil. Ta
Make sure the surface finish is fine so theres no stress risers
Another job on the imaginary list. I'll never get the car finished at this rate...
best_stig
Member #: 6449
Brisbane, Australia
What are the advantages?
They can be lightened easier?
And does it effect the geometry at all?
I have two sets btw, one on my old daily and one set i was going to replace with something aftermarket.
In boost we trust
According to the threads I have been reading, they improve handling a bit, but are heavier.
How much do you want posted for a set?
Ben H
Member #: 184
Melton Mowbray, Pie Country
The hole for the knuckle joint is further along the arm, towards the ball joint. This effectively increases the spring rate. It helped our car.
http://www.twin-turbo.co.uk
best_stig
Member #: 6449
Brisbane, Australia
Been a few days since I've been on. I'll have to pull them out of my shed tomorrow and get a weight for them.
In boost we trust
I'd be interested in a set too and could combine postage with Andy.
I run a set and i had to get the mk1 bump stops and cut them down a bit.
just so you know mate.
Thanks Si.
