Home > Wanted > Split rim bolts/nuts 120 off
Dangerous
Member #: 417
The ones I am after are m7 x 32 with a 10mm long plain shoulder under the head for location/sealing.
THe heads are 10 pointed stars,I just spotted the same heads on a bloke at works 4x4.
would these be the same as they use on the mini 10" split rims.*crying*
Any ideas where I could try to get them I was thinking about going up to m8 stainless bolts but the bolt supplier thinks they are extra high strength jobbies and don't really want them falling apart on me *tongue*
I know a guy who can get gold plated / chrome ones for £100 - the ones for BBS Splitties.
mikemph
Member #: 449
Oxford
Try RS
Or Thames Valley Bolts and bearings maybe worth a try
m7? sounds expensive! I have had to buy m7 bolts for things before (vauxhall crank pulleys, peugeot sump cap heads) and they are damm expensive, e.g. I paid 75p EACH!!!!!
If I were you I would go up to m8, as long as you get bolts of sufficiently high quality and GRADE then you should fine.
Iain has recently had to get a load of split rim bolts, ask him where he got his from?
Dangerous
Member #: 417
I've tried pristine and image wheels no joy,so it could be go up to m8
The wheels are oz turbos by the way on a mk1 golf the nuts are oz too mind you there 20 years old
I just got some 12.9's from my local nut and bolt place. not that happy with them though. no shouldered section on mine at the mo but its the same as they came out.
im going to sort some new ones asap.
E30 M3 rocker cover... M7
Dangerous
Member #: 417
Trying
www.forceracing.co.uk
next as they make wheels
aka fastcarl on here *wink*
try wessex fastners in old town mate they have got me some really odd stuff in the past
