Home > 998cc > 998 turbo parts advice
jdisel
Member #: 9515
ireland
Im just ordering the parts i need for my engine build as i want to see can i send off my engine to the machine shop in the next couple of months but not too sure about a couple parts that i need.
Im fitting a 12g295 head to the engine but i want to get the valve guides changed as well as changing the valves to stainless ones and maybe fitting unleaded valve seats, my origional plan was to go with these valves C-AEG587 and C-AEG588 but im worried that the inlet valves wont be big enough as the standard inlets in the head look to be sitting too low, dont fancy having to get unleaded valve seats fitted in the inlets too,
i attached a few pics but i wondering if the minispares valves are slightly bigger than the standard ones and if ill get away with them or could ye reccomend a bigger valves size.
Also would fitting unleaded valve seats increase the chance of the head cracking as ive heard there prone to doing this.
I also need to get a timing chane setup, have minispares any race one that would be ok, cant seem to find any suited to modified engines,
Im missing the inner valve sping on one of the valves, would i be better off just getting a full replacement set or is it worth inspeacting the rest of the springs first.
Im sure alot of simular questions have been asked before but cant seem to find what im looking for.
Any help would be great
A job worth doing is a job worth over doing
For the head the best I have found is 33 inlet and 29 exhaust with unleaded seats on the exhausts.
Problem is that you have to use the valves from the 1275 head as they are the only ones available. Someone on here will tell you the trick to fitting them, as I don't know.
Yes just buy a new set of springs.
Any timing chan will do the job, stick with steel though if you plan on doing some miles.
The 29 exhaust valves will hang over the block so you either sink them into the seat a bit or pocket the block.
The 1275 valves are longer so you have to put shims under the springs. Turbo phil sorted mine out but I had the 29mm valves cut down 27.something
Advantage
Member #: 1450
Near Paris - France
IIRC spring deck height is different so standart height spring gives lower than expected pressure.
Maybe they need shimming under the springs.
Edit : too bloody slow !
Edited by Advantage on 17th Jan, 2012.
Rusty by nature
If you are not planning on running high boost, then a set of machined down 1275 valves would be OK.
Say 32mm inlets to deal with the seat recess and 26.5mm exhausts that should clear the block. However, if the head is not skimmed then that wont be an issue anyway. Open up the throats to suit.
I can let you have a set of washers to space up the valve springs. I bought 100 when I only needed 8 !
Edited by Paul S on 17th Jan, 2012.
I use 29mm valves on a +20 and it clears ok.
jdisel
Member #: 9515
ireland
Cheers for all the replys,
This is my first engine rebuilt so was hoping for a more straight forward solution.Im gong +20 too so will this mean i wont have to pocket the block or anything if i fit 29mm exhausts. Im aiming for the region of 100bhp if thats achievable, Was thinking of going with a gt1544 with 10 - 12 psi boost. But it would be nice to be able to up the boost a little for thoses special ocasions *hehe!*
So want to do it right while im at it.
Whats the biggest valves available for a small bore, the only thing is i dont know what it will take to get the inlets sitting right, This might be a stupid question but is the valve stem diameter the same in the 1275 valves as in the small bore ones.
Is opening up the throats something you could do yourself,
Would these inlets the ones your on about http://www.minispares.com/Product.aspx?ty=...id=37567&title= or would the standard 1275 one do.
and are these the exhausts http://www.minispares.com/Product.aspx?ty=...id=35889&title=
Thanks again
Edited by jdisel on 17th Jan, 2012.
The 29mm exhaust valves will be OK provided that the head has not been skimmed and you are not going too high with the valve lift. They could hit the top of the block.
On one of my builds I'm using a heavily skimmed head with a highish valve lift and the valves go into the bore at maximum lift. 26.5mm is the largest valve that you can use on a +0.020" bore in that instance.
A set of second hand 1275 valves would be OK. Stems are the same as the 998s.
jdisel
Member #: 9515
ireland
I might be needing them, cheers, ill drop you a pm if i need them.
Im gong with a mg metro cam but i must double check the chamber size as i keep getting inconsistant results, i might just get a calliper and measure the thickness of he head, but is there a noticable difference in performance if i went with 29mm exhausts over 26.5mm ones,
26.5mm exhausts might just be an easier and safer option and 33mm inlets from an old 1275 head, what do ye think
Edited by jdisel on 18th Jan, 2012.
If you are using that ladyboy cam :) , then you've only got around 8.0mm lift, so makes like a bit easier.
As for exhaust valve size vs performance, then all I can say is that I'm running 120hp on 26mm and the new build should do 150hp with 29mm valves by just allowing it to breathe easier and rev a lot higher.
jdisel
Member #: 9515
ireland
In that case these should be more than up to the job for my planned hp.
http://www.minispares.com/Product.aspx?ty=...id=33367&title=
I got that ladyboy cam *smiley* was i thought it was a decent cam for a 998 turbo, alot of people seem to be running them, do you think its not suited.
So would anyone have a decent set of 33m inlets that they would sell, or am i beter off going new
Oh ya, would the standard cast duplex timing gear from minispares be ok to use,
Thanks again lads for all the replies.
Nothing wrong with the MG cam, it's a safe bet. I would just like folks to try something else, so we can get a bigger picture.
Not sure what you can do for short, small bore 33mm valves.
wez
Member #: 9271
Stoke on Trent
What sort of cams would you like to see used? Any specific ideas?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
I've got good results from the MD274, but I would like to see if others do too.
Then theres the RE13T or whatever it's callled, although probably a bit too much for a 998.
I'm currently doing a 998T build with a short duration scatter pattern cam and I'll post the results as soon as I have them.
jdisel
Member #: 9515
ireland
Safe is good for me at the moment, ha
Its my first build so want to go with something that i know works, i can always experiment after.
Sorry meant 1275 ones, wasnt very clear, but i was looking through some old topics and Paul Ivey's name came up for a fella that i could buy some new small bore 33mm valves and 26.5 exhausts from,
http://www.turbominis.co.uk/forums/index.p...tid=342805&fr=0
I realise its an old post but does anyone know if he is on the fourm and if he still does them,
Paul Ivey does the "Rimflo" valves.
I use the 266 in the sprint. and on my hillclimber I use 33 29 valves and that has more than 150bhp. I tried bigger with poor results.
jdisel
Member #: 9515
ireland
Would the 33mm rimflo ones be alright to use as the inlets.
Another thing, what kind of main and big end bearings would be the best, Ive been looking through the fourm but still not sure would i need to fit the earlier type ones and get some maching done or will the standard later replacement ones be ok. the less maching the better so would like to see can i get away with the later type.
Advantage
Member #: 1450
Near Paris - France
One of these days, I'll build a 12G295 31 / 27,5 998 with a MD 256 and GT15 of a diesel ...
We might run out of petrol before that thought ...
Rusty by nature
