Home > For Sale > Plenum for K heads
xuminimaniac
Member #: 9431
Portugal - Lisbon
Hi there.
I've got this plenum for sale or for swap.
I've machined it when I develop and machine my K convertion kit and the plenum was only to start the engine because I had no carbs.then I've got a matched webber 40"s and let the plenum on the shelf as you can see only have machine the holes in the plenum with the center holes of the intake and for fixing it to the head.
It may need some work to be perfect some chamfers on the intakes.... but the hard hork is done.
the alloy used is 7050 and for the two flanges between plenum and head the alloy is 7075 ( the 7075 alloy are the best as used in aerospace industry and the 7050 are one of the 2nd one best ally's)
I intend to swap it for a K 8V or 16V head (head cams and cam cover).
more pics please e-mail.
Im happy to pack and ship wordwide.
Edited by xuminimaniac on 17th Jan, 2012.
Looks good, but where did you plan to put the injectors??
xuminimaniac
Member #: 9431
Portugal - Lisbon
I machine it with the intention only of attacht a HIF just to try my convertion.I guess if injection is to be used the plennum can be machined down a bit to get room for the throttle bodies.
