Home > Help Needed / General Tech Chat > Carb for supercharger
JeroenH
Member #: 9761
Hello i am jeroen from holland,
I am new here.
I am building a Clubman estate with a 1293 supercharged engine.
I have a question:
Do you need a seald carb for a supercharger setup just like the turbo?
Do you need for a supercharger also a return pipe for the fuel?
Not if it's before the supercharger I.e like a vmax kit.
JeroenH
Member #: 9761
Thanks for the fast reply.
I have searched here but didn't find the answer.
And the fuel return pipe is also not needed?
Edited by JeroenH on 17th Jan, 2012.
Nope as the carb will be the same as running on an NA engine.
As long as it's suck-through then it's just the same an NA setup.
I am new here.
I have a question:
What setup are you running ? What supercharger and how is it configured ? Also, what carb ?
JeroenH
Member #: 9761
Its a setup from vmax with a hiff 44, and a MED build engine with a lower comp for the supercharger.
Edited by JeroenH on 19th Jan, 2012.
In Which case, a NA carb will do the job. There is no need for a turbo carb because it is before the charger and won't 'see' boost.
