| Home > Help Needed / General Tech Chat > T2 with mirage manifold bleed valve or actuator | |||||||
![]() 183 Posts Member #: 9548 Advanced Member Manchester |
18th Jan, 2012 at 10:30:33am
I do not have a actuator and my turbo has been moded so the arm is on the other side for the actuator so the question is if I'm fitting a bleed valve do I need a actuator and if so which one do I need as I'm planning on running 12 psi sorry if this has already been covered I did search http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
18th Jan, 2012 at 10:51:52am
You need both. You also need to have a read up on the basics of how a turbo works and how it controls, what the wastegate actuator does, and what a bleed valve does.
18th Jan, 2012 at 10:53:05am
Yes you still need an actuator.
18th Jan, 2012 at 11:03:13am
Thx so much http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
