| Home > Help Needed / General Tech Chat > Mounting a Kenlowe | |||||||
478 Posts Member #: 1962 Senior Member Lancaster |
19th Jan, 2012 at 07:25:52pm
How do gents
19th Jan, 2012 at 07:55:34pm
I copied Keiths abave and made some brackets out of some L ally I run a supercharger and I don't care the TB is on the wrong side.
19th Jan, 2012 at 08:35:26pm
Just seen simon's as well |
43 Posts Member #: 9469 Member letchworth herts |
19th Jan, 2012 at 09:54:11pm
Is it better to cut the vent section from the inner wing for better air flow ? |
20th Jan, 2012 at 08:12:15am
The first picture is a bit crap IMO, too many gaps around the fan and between the fan and rad for it to be efficient at frawing air through.
20th Jan, 2012 at 08:22:56am
On 20th Jan, 2012 wil_h said:
The later minis had a circular hole in the inner wing to fit a fan, which is the best way. This.
20th Jan, 2012 at 10:59:44am
Cheers folks, not that keen on the idea of having weld a new inner wing section in, but I get the idea that the fan needs to be closer to the rad.
20th Jan, 2012 at 11:10:32am
Thats probably what id do.
On 20th Jan, 2012 tomkidd said:
Cheers folks, not that keen on the idea of having weld a new inner wing section in, but I get the idea that the fan needs to be closer to the rad. By the way this isn't the only fan, I am running the additional one. Do you think I could cut the slated panel out of the inner wing and just fasten the kenlowe to the radiator? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Jan, 2012 at 11:26:53am
Only fear with this is that the rules say I can't cut the inner wing I think? |
20th Jan, 2012 at 03:07:51pm
Just been studying the car in the workshop... Think I am going to mount the fan as the above photos and make some ally ducting a similar style to a clubby inner wing if it struggles. I'd have to chop a lot of inner wing out to get the fan on the engine bay side.
20th Jan, 2012 at 03:09:24pm
Just as a side, why do you think you need an extra fan?
20th Jan, 2012 at 03:10:57pm
Just mount it to the wing like i did mate. worked very well. I still have the alloy bits in the shead some where if you need the dems.
Edited by madmk1 on 20th Jan, 2012. I have started posting on Instagram also my name on there is turbomk1golf
