| Home > FAQ / Knowledge > New Rings? End Gap Too Large? | |||||||
24th Jan, 2012 at 12:04:38pm
http://www.diagnosticengineers.org/journal...edge%20Gaps.php On 26th Oct, 2004 TurboDave16v said:
24th Jan, 2012 at 12:28:33pm
interesting On 11th Feb, 2015 robert said:
24th Jan, 2012 at 12:28:55pm
Interesting.
24th Jan, 2012 at 12:55:03pm
I remember reading about that somewhere years ago. I can't say ring gaps have ever been top of my list of concerns ever since. Just goes to show how much complete bollocks is talked about engine building. |
24th Jan, 2012 at 01:40:39pm
huh, that was certainly interesting. Reciprocating refrigerant compressor manufacturers also say that the gaps in piston rings be staggered. And I acctually beleived in it! Thats that out the window then.
24th Jan, 2012 at 01:58:03pm
I think the coin drops when you consider pegged rings
24th Jan, 2012 at 02:10:18pm
I've read a few articles saying that total seal rings are snake oil.
24th Jan, 2012 at 02:30:25pm
he said they smoke after a while sat idling On 11th Feb, 2015 robert said:
24th Jan, 2012 at 02:33:18pm
On 24th Jan, 2012 John said:
I've read a few articles saying that total seal rings are snake oil. Also I'm sure John Sleath mentioned to Andy when we had the van rollered that he has known motors that have burnt oil and blue smoked from new with total seal rings. But swap them out with conventional ones and the problem goes away. How many people read the instalation instructions and follow them though. I know I was flamed on this very forum when I said I lubricated the TotalSeal rings with WD40 on instalation, even though TotalSeals instructions were clear, as the 'norm' is to use engine oil to liberally lubricate the rings on instalation. I've used convensional and gapless TotalSeal rings without any worries, and all were installed with WD40. Fact of the matter with the Total Seal rings that I have used, is that they were the only rings available for the pistons I have, so the gap/ gapless thing is irrelevant to my purpose
24th Jan, 2012 at 02:34:48pm
On 24th Jan, 2012 apbellamy said:
he said they smoke after a while sat idling I wonder what the mechanics are behind that On 26th Oct, 2004 TurboDave16v said:
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
24th Jan, 2012 at 03:06:56pm
he said they smoke after a while sat idling I wonder what the mechanics are behind that one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
24th Jan, 2012 at 09:17:19pm
However, it's a good thing to measure ring gap as we all know what happens if it's too small.
24th Jan, 2012 at 09:26:17pm
I've been told that the pattern In the honing is to hold on to the oil residue??? Any truth in that? one day boost will be mine!
25th Jan, 2012 at 12:31:37am
That is what I was taught too, shinny bores don't hold onto oil Own the day
25th Jan, 2012 at 11:55:12am
No one is disputing the hone is what 'lubricates' the rings in a running engine, but a 90 cross hatch would hold onto oil just as much. I'm with Vegard. On 26th Oct, 2004 TurboDave16v said:
25th Jan, 2012 at 02:03:42pm
I've read a few articles saying that total seal rings are snake oil. Also I'm sure John Sleath mentioned to Andy when we had the van rollered that he has known motors that have burnt oil and blue smoked from new with total seal rings. But swap them out with conventional ones and the problem goes away. And I spoke to a very professional builder just recently, and he stated that if you're blowing smoke with Total Seal rings, or indeed any rings, your bore finish must be horrific, or piston bore clearances horrific. Either way a build issue, NOT the rings. Quite relevant to the post above actually. Piston ring gaps are important. But only from the point of view that too tight can lead to seizures with catastrophic consequences. Ive used Total Seal gapless and non-gapless on many engines. Never have I had an issue with them being smokey or burning oil that wasnt down to the two things I mentioned. And even then, it was only 2 that burnt a little oil ( never visible ). None have ever been smokey. That's n/a engines through to turbocharged running near 40psi boost. As for gapless offering any benefit ? Who knows. If it is measurable, probably a very small one. But then it's usually only 1 ring of the pack that uses their gapless design ( but of course there is still a gap and normal gapping rules must apply. ie, not too tight ) And rings do rotate. If they all end up with the gap in the same spot on any bore...it's usually a sign of the bore not being totally round. 9.85 @ 145mph
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
4th Mar, 2012 at 11:14:39am
I discussed ring gaps with three eminent engine builders down the pub after the Autosports show (see current editorial pic in Mini Mag for a clue).
Metric is for people who can't do fractions. |
![]() 36 Posts Member #: 9909 Member Tyler, Texas |
26th May, 2012 at 01:35:35pm
First off this guy contradicts himself, saying that the ring gaps dont have to be staggered then he goes to say that when they are staggered they make a "maze" so you dont get blow by....
-1974 Mini 1000 - BRG Turbo Build Soon to come
389 Posts Member #: 9751 Senior Member Derbyshire |
26th May, 2012 at 03:03:42pm
I used to build 600+ bhp leman engines and have installed rings with gaps opposite etc. put the engine on the dyno, strip after and the rings gaps are all over. Regarding gaps. They had to be precise and the edges on the rungs were de-blurred under a microscope.
Edited by mossy2a on 26th May, 2012. |
