Home > Introduce Yourself > runnin gear
kieron
Member #: 9773
im thinkin of buyin a 1275 clubman what would i have to do to metro gti 16v 1.4 would i have to put the runnin gear from the metro on the 1275 plus i want a small turbo fitted what type do you surjest what bother's me 1275 is leyland but the metro is rover could it be sorted*oh well*
Edited by Nick on 25th Jan, 2012.
Amp
Member #: 7856
If you are putting a 16v engine in, try:
http://www.16vminiclub.com/forums/
That website should have all the answers you need regarding the 16v 1.4
best_stig
Member #: 6449
Brisbane, Australia
I voted...... and theres the full stops you missed.
Sounds like a lot of work really, guessing the 1.4 is a k series?
In boost we trust
I think you're a little confused.
"running gear of the metro on the 1275" eh?
Basically what you are wanting to do is put a totally different engine and gearbox in your car. In this case, a K-series rather than the A-series. But the process is no different that if you wanted to fit a Vauxhall red-top or a Vtec.
It has been done plenty of times (and Denis one here has turbo'd his too). But it's not a simple swap. as suggested above, go to the 16v mini club website, there is a welth of info on what you need to do.
they like you to use the search on there too...
