| Home > Help Needed / General Tech Chat > Timing a Kent 286 - Advance it or not? | |||||||
25 Posts Member #: 1120 Member Durham |
30th Jan, 2012 at 01:26:34pm
Spent yesterday evening checking the timing with my Kent 286. The 286 Lobe centre angle is 106. When I checked the dot to dot timing the crank was at 107 degrees when at full inlet lift. Ie, 1 degree out.
30th Jan, 2012 at 01:50:25pm
Is it na or turbo? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
30th Jan, 2012 at 01:58:38pm
Bushman, have you got plenty of compression to make it work? If you remember my old road Mini engine from 1999, that had a 286 in it, it was a bloody pig below about 3000rpm, looking back the compression ratio wasn't really high enough.
30th Jan, 2012 at 02:03:49pm
If this is going in a turbo for road use it will not be a nice drive! Seriously been there done that worst choice of cam I could have made but live and learn. Own the day
30th Jan, 2012 at 02:08:32pm
Its an N/A.
Edited by JTBush on 30th Jan, 2012. |
30th Jan, 2012 at 02:14:46pm
On 30th Jan, 2012 Tom Fenton said:
Bushman, have you got plenty of compression to make it work? If you remember my old road Mini engine from 1999, that had a 286 in it, it was a bloody pig below about 3000rpm, looking back the compression ratio wasn't really high enough. The maroon one? Would often stall on the run into uni. Grumpy little bastard wasnt it. I took the engine into Green and Whites after Steve sorted my cylinder head and told them I wanted the block/ combustion chambers finishing to give me a CR so I wouldnt need to use lead additive but high enough to use a 286. I have 11 - 1 in mind but it was a while back now. |
30th Jan, 2012 at 02:29:40pm
The engine in question was in the maroon one then went into my blue Clubman Estate, yes it was a grumpy little bugger, great when it was on song above 4000rpm but crap otherwise.
30th Jan, 2012 at 02:41:58pm
Ill measure the CR this week to confirm it.
30th Jan, 2012 at 06:19:08pm
You want it at 104 if its a new chain, I wouldnt go as far as 107 I seriously doubt it! |
30th Jan, 2012 at 07:46:26pm
It's a used chain |
30th Jan, 2012 at 07:51:11pm
Time it at 106 then.
6th Feb, 2012 at 10:34:47am
New chain on, timing now smack on 106. So, do we adjust for chain stretch? Ie, a 2 degree offset key.
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
26th Feb, 2015 at 09:29:37am
Rather than starting a new thread, just timed in a 286 with new chain at 104.5? Opinions. Should I aim for 104? On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
26th Feb, 2015 at 09:49:52am
imo with cams and cr you want to work out the valve closing angle then take that stroke length for you calc as you want dynamic cr not static/spewed
Edited by Turbo This.. on 26th Feb, 2015. |
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
26th Feb, 2015 at 11:43:16am
My advice is to sell the cam if it's for a road car. I had 1 in my old min with 11.1 compression and using an octane booster. It was an absolute bitch to drive unless on open A roads Masturbation is not a crime its a hobby |
27th Feb, 2015 at 10:43:24am
i was interested to see the dynamic cr of the 286 and 11-1 cr so put it in the calc and its only 8.65 so any wonder its no fun at the bottom end about 175psi calculated (perfict world)
27th Feb, 2015 at 11:14:13am
14:1? Seriously? You would not be able to run anywhere near enough ignition advance to make decent power.
27th Feb, 2015 at 11:19:05am
completely off topic but I always liked the 286 back in the day; worked well as a budget build with an MG head and stage 1 kit |
27th Feb, 2015 at 12:01:27pm
Having been there and done it...
336 Posts Member #: 9941 Senior Member Derby |
27th Feb, 2015 at 04:09:32pm
I agree my 286 cam was ace in a na engine I'd imagine there terrible though if the resr engine isnt specked accordingly |
