| Home > Help Needed / General Tech Chat > metro turbo engine camshaft bearings | |||||||
11 Posts Member #: 8838 Member INVERENSS |
30th Jan, 2012 at 08:10:57pm
Just a quick one. Iv got a standard metro turbo engine and have just stripped it down for a rebuild. Im needing to get a set of camshaft bearings. Can i buy and fit a set of bearings for a 1275 or do i have to try and find ones for a metro turbo IV BEEN IN THE WOODS TO LONG TO HAVE BEEN FUCKED BY A CROW |
30th Jan, 2012 at 08:14:40pm
30th Jan, 2012 at 08:26:00pm
Spot on cheers IV BEEN IN THE WOODS TO LONG TO HAVE BEEN FUCKED BY A CROW |
30th Jan, 2012 at 11:40:14pm
All cam bearings are the same. Just make sure you align the oil holes ! 9.85 @ 145mph
![]() 146 Posts Member #: 9421 Advanced Member Bardwell, suffolk |
30th Jan, 2012 at 11:42:01pm
Is it a job you can do at home easily? Or do they need to be pressed in?? |
31st Jan, 2012 at 07:15:01am
You need a special tool to make sure you get them in straight without squashing them.
Edited by apbellamy on 31st Jan, 2012. On 11th Feb, 2015 robert said:
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
31st Jan, 2012 at 01:42:38pm
yes you need a special tool as apbellamy says above - I found out the hard way a couple of weeks ago. If the camshaft doesnt literally push in then its all wonky and needs sorting out - dont hammer it in like I did, craigfail :(
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
31st Jan, 2012 at 03:37:18pm
On 30th Jan, 2012 stevieturbo said:
All cam bearings are the same. Just make sure you align the oil holes ! All big bore ones are the same. However, you can fit 998 ones in a 1275 but not vice versa. On 13th Jul, 2012 Ben H said:
