Home > Help Needed / General Tech Chat > fuel pump options
jamz
Member #: 2292
Tool
Herne Bay, kent
can anyone point me in the right direction to what fuel pump i should get for around 180bhp target? do i just need one fuel pump if im running an alloy tank? ive seen people have 3 when they have a swirl pot set up?
ive got a miglia tank on order from endaf with the take offs at the bottom of the tank.
cant beat a good blowout.
A swirl pot is needed more for injection cars, as there is no float bowl and the injectors rely on the fuel pressure for the fuel to flow through.
On a carb setup you have a little bit of leeway.
Also if the tank is designed with a sump in the bottom then hopefully it should always have fuel to supply to the pump.
Pump wise there are lots of external injection pumps that will do the trick. The DON uses a Bosch Cosworth pump for example, but there are lots of options on ebay.
jamz
Member #: 2292
Tool
Herne Bay, kent
after speaking to endaf. we decided on a non sumped tank but baffled with twin outlines either side that y piece into one before the fuel pump. so then i just need the one injection fuel pump of anything turboed?
jamz
Member #: 2292
Tool
Herne Bay, kent
will this pump be ok?
http://www.ebay.co.uk/itm/SYTEC-LINE-HIGH-...#ht_2585wt_1163
