| Home > Beginners Tech > Turbo Piston Rings | |||||||
389 Posts Member #: 9751 Senior Member Derbyshire |
2nd Feb, 2012 at 09:26:43am
Interesting....
2nd Feb, 2012 at 09:37:15am
Buy total seal. At least you know for sure they will be right. If something is worth doing, it's worth doing half of. |
2nd Feb, 2012 at 11:57:29am
Why not find out if they are the real thing for sure. How hard can it be? On 13th Jul, 2012 Ben H said:
2nd Feb, 2012 at 12:44:25pm
Maybe some people have better things to do. I think I'd rather spend an extra fiver than risk getting the wrong rings. If something is worth doing, it's worth doing half of. |
2nd Feb, 2012 at 01:09:20pm
Looking at previous posts regarding the wrong oil scraper ring supply, i am tempted to simply go down the total seal ring route.
2nd Feb, 2012 at 01:15:09pm
Me and Andy ran TS rings in the van. No problems. If something is worth doing, it's worth doing half of. |
2nd Feb, 2012 at 01:42:07pm
only for about 2k miles though. had no sign of wear in the bores and the honing still looked good On 11th Feb, 2015 robert said:
3rd Feb, 2012 at 03:25:37pm
A bit more info.... just spoke with said supplier of the std tyurbo rings but the oil rings they have are 3mm, which i believe is incorrect and they should be 3.5mm.
